Re: LG LST5651SW stove: oven not heating properly
Since the top element (broil) works, I would suspect that RY6 is bad.
It may or may not be getting told to turn on but to check that it would require working on a live oven.
You could give the smaller relay a couple taps with a screwdriver handle and see if the bake element comes on, then you know the relay itself is bad.
From the pictures: Everything looks OK, board soldering has a few rough spots but no big fractures. There is no thermal safety switch in this model.
I do see a blackened diode with splat of solder, on the relay on the right. I'd look to see if the relay spit some molten metal or what. Both diodes should look identical.
RY6 is Bake, RY5 is Broil, RY8 DLB is the safety relay for both.Last edited by redwire; 01-08-2023, 05:17 PM.Leave a comment:
The connections look ok. That leaves the relays, so either the relay contacts are burnt and not closing OR the coils are not being energized (turned on). I would suspect the smaller relay (RY6) could be bad as it connects directly to the lower element
Is this wire (red arrows) all connected to the same point (red ac line in)?Last edited by R_J; 01-08-2023, 05:14 PM.Leave a comment:
The two black plastic relays are marked Potter & Brumfield T9AS1D22-12.
The solders look good to me. They are all shiny and reflective though the photo doesn't capture that. Some have a dull spot in the middle.
NO, on the black plastic relay itself. but I think I figured out the pinout
Have you removed the board and checked the solder connections?
It looks like the smaller relay (RY6) is the one that controls the bake (lower) element
Does that sheet diagram show how the elements are connected to the relay board?Last edited by R_J; 01-08-2023, 04:50 PM.Leave a comment:
I marked the relay board photo with three red lines. Any combination of these test OK for continuity. Of the six connecting posts on the board, no other combinations test OK for continuity. If that means anything...
Please excuse my ignorance. I have pretty good common sense, but little electrical/electronics knowledge. I'm learning as I go.
The big sheet that was attached to the back of the stove has diagrams but doesn't mention a test mode, only instructions to test for continuity, and what the ohms reading should be for all the components.
How do I properly test the relay board?Leave a comment:
no, i'm talking about creating an induction coil to obtain some mV based on the current flowing into the heaterLeave a comment:
Most ovens will turn on both the main element and the broil element to get the oven up to temperature faster (preheat), In this case it seems that only the broil element is being tuned on to get the temp to 365, If the lower element is not operating it is either open or not receiving any voltage.
Locate the relay board and check it.Leave a comment:
Yeah that's an old trick of seeing a millivolt voltage drop across a wire or fuse which indicates current flow. We don't know if there is power to the bake heater or current flow when the oven is hot and craps out.
Hey, I looked a bit more and apparently LG ovens have thermal limiters (fuse) i.e. https://www.reliableparts.ca/product...al Safety Fuse
OP, can you post a picture of the back wall of the oven?
You would be able to see one of these, or spot bad connections etc.
Usually a bad connection or relay contact will make heat and burn/melt things as well as a zzzzzzt sound. They can stand out.
edit: there was an LG recall for this stove. "The burners on the electric ranges can fail to turn off after being switched off or the temperature setting can increase unexpectedly during use, posing burn and fire hazards to consumers. To determine whether your electric range is being recalled, please follow the instructions below."
https://www.lgelectricrangerecall.com/Leave a comment:
wanna try something questionable?
in theory if you wrap a few turns of insulated wire around a power cable and then hook the ends to a voltmeter it will show current-flow as volts.
but i dont know the turns-ratio so you could get mV or you could get much higherLeave a comment:
It sounds like there's simply not enough heat to get the oven past 365° with only the broil element puttin' out.
As was mentioned, the bake heating element (or relay circuit) could be going bad, open-circuit when it's hot.
You're going to have to troubleshoot it. I could not find the LG service manual which has a test mode and wiring diagram to make repair easier.
Post pics of the relay board backside, I suspect a intermittent connection to the bake heating element or a bad relay.
The temp sensor if bad will show the wrong temperature or an error code. It looks fine. A multimeter continuity test is for wires and connections, readings under 100 ohms beep so it's normal for a thermistor to fail a continuity test at 1,000 ohms.Leave a comment:
More info:
No error code shows on the display. On the product sheet, there's an error code table, with "F7 Main oven heating error" that covers both oven heating elements, sensor, and PCB.
It seems to get up to around 365 and stops. I'd been setting it to 400 450 to test. Now I set it at 300. When it gets to 300 and the preheat complete alert -- beeping and flashing oven light -- goes off as normal.Leave a comment:
LG LST5651SW Parts with 6871W1N012B oven relay board like https://www.reliableparts.ca/product/inv_16906185
You should be able to hear the relay clunk, or swap the wire with the bake/broil heating element.
edit: weird the board shows no "BROIL" spade terminal, even the 6871W1N012A with extra relays doesn't show it.
I would do a visual for bad solder joints on the relay board, including the connector to the (other) oven control board.Last edited by redwire; 01-07-2023, 08:44 PM.Leave a comment:
It looks like there is a oven relay control board in this stove, I would check the relay solder connections, then check the relay operation.Leave a comment:
I removed the element. There's no damage, corrosion, anything like that. It looks perfect. There's no visible damage and the resistance is to spec -- does that mean that it's fine?Last edited by Curious808; 01-07-2023, 06:24 PM.Leave a comment:
you could check the voltage is getting to itLeave a comment:
I haven't actually removed the element, only disconnected the wires. Would I be able to get a more useful reading if I plugged it back in and turned on the oven for a few minutes before testing? Or if I removed the element, would it likely show physical damage?Leave a comment:
by JayPoorJayWhat could go wrong...?
I'm not sure if this is the right sub category or even the right forum but here goes,,,
I'll just dive right in. I want to see if it's possible and what it would take to use a PID Controller (or 2) to run a central air conditioning heater element (the kind that goes into an air handler) and a small blower fan... The application is a DIY Sauna... Am I nuts? Mean, these components could be had for around 100 bucks.
What do I need to be thinking?
Of course I will go to Vevor and order one of their 200$ sauna heaters so I... -
by EasyGoing1I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
This is the general setup that I have now.
This is what the... -
by bohabohaHow to test this queen coffee maker heating element...
by flyskyThere is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.
by CuriousJohnBurco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot... - Loading...
