Diesel heater emergency power supply / poor man's UPS
  • madan1
    • Nov 2016
    • 707
    • Bulgaria
    Hello everyone.
    Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and thus transfer energy from the heater body. For PSU I use a PS3 power supply, which has 12v and 5v outputs. The heater works with 7-16V and it has no power regulation/stabilization for the glow plug and the fan (it has only for the ICs on the motherboard).
    I guess many of you already see the problem, which will happen if the power supply is interrupted - the fan stops cooling the heater body while in the combustion chamber there are still fuel and (some) air to continue the burning process. This might cause temperature increase in the case, enough to damage the motherboard (the heater body can easily reach up to 210-220 C* when running).
    So I'm thinking about some kind of a basic (and cheap) temporary/emergency power supply. What I have in mind is a car battery in parallel with the psu 12v rail and a 5V relay which will cut the pulse signal to the pump (see attached image). This way, when there is a mains interruption, the psu will die and the signal to the pump will be cut, which will be detected as an error by the heater's brain and will force it go into power off cycle. The normal power off procedure also keeps the fan running until the heater body reaches safe temperature.
    When the glow plug is on, the unit consumes about 12-15 amps (~150watts if I remember correctly). When the glow plug is off (most of the time), the unit consumes less than 1 amp.
    The psu specs are 12v 20+A and 5V 1A
    So please check the drawing I made and give your suggestions on how to improve it. Thanks in advance.
  • CapLeaker
    Leaking Member
    • 8313
    Re: Diesel heater emergency power supply / poor man's UPS
    My quick thought about it is that you fix one problem but still have the same problem reoccurring later, when the power hasn’t been restored and the battery goes flat.
    • madan1
      • Nov 2016
      • 707
      • Bulgaria
      The power off procedure lasts for like 5 minutes. My idea is just to have enough power to safely auto-shutdown (triggered by the disconnected pump or just starving from lack of fuel) avoiding damage to the motherboard or even worse. I do not intend to run it on battery.
      I also hope that the battery will recharge when the mains recover and the PSU turns on.. and here is one of my main concerns - does the battery need some kind of current limiter or it can take the full 20+amps from the psu?
      P.S. The heater needs some "human touch" to turn on, while the PSU is rigged to turn on automatically.
      • CapLeaker
        Leaking Member
        • 8313
        Aah, important information… well, as far as the battery goes, you probably thinking of a lead acid battery. There are flodded or SLA (glass mat). These need specific float voltage. To little and the battery is never charged full and Sulfates after a while. Too much and you boil the battery dry. So you may have to convert your PSU to variable output.
        • the old man51
          • Dec 2022
          • 11
          • yorkshire
          https://www.youtube.com/watch?v=TWC5...=DavidMcLuckie
          try this guy
          • the old man51
            • Dec 2022
            • 11
            • yorkshire
            this broad scotish
            • madan1
              • Nov 2016
              • 707
              • Bulgaria
              Originally posted by the old man51
              Well, checked some videos, but nothing concerning my issue, apart from proving that my theory about disconnecting the fuel pump will actually put the unit into a powerdown cycle.
              So the main question continues to be - is it OK to just put a lead battery in parallel to the power supply or I need to use some kind of circuitry with it.
              • petehall347
                • Jan 2015
                • 4435
                • United Kingdom
                just run it off a 12v battery as its designed for and leave the battery on an automatic battery charger .. i run a few things like that no problem .
                • edugimeno
                  Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                  by edugimeno
                  Hi!!
                  Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                  I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                  At a certain point, moving stuff around, I put all wires back in place and...
                  03-24-2024, 02:31 PM
                  Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                  by sam_sam_sam
                  I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                  I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                  12-16-2023, 08:39 PM
                • sew333
                  Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                  by sew333
                  Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                  So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                  So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                  I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                  06-14-2024, 07:30 AM
                  Tankless hot water heater controller board not powering up when power is applied
                  by sam_sam_sam
                  I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                  I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                  However I would like to know if I could figure what happened to this controller board if possible
                  Tomorrow I will take some better pictures of both side of both boards
                  The...
                  12-09-2022, 09:14 PM
                • hikomalek
                  SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                  by hikomalek
                  Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                  When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                  Transformer:
                  |Info| Primary | Aux | AB | CD|
                  |Ratio|1|25|40|12|
                  |Voltage AC|230V|9.2V|5.8V|19V|
                  |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                  I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                  09-19-2025, 03:30 AM
