Polymer cap ratings
  • Lance Thornton
    • Jan 2005
    • 84
    Polymer cap ratings
    I hope this is not a double posting, but I would like to know the method of replacing an aqueous cap with a polymer one. Specifically, are there any formulas that would help me buy or size the right one if I'm replacing a 1000uf@6.3 volts, etc. I assume that the diameter must be equal or smaller, depending on spacing. I also wonder about the heat issues with polymer capacitors rather than electrolytic. My apologies if this question has already been posted.
    Thanks all,
    Lance
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Polymer cap ratings
    it can be hit and miss.
    the two values you need to keep in mind are the voltage and esr:
    voltage- lowest voltage that is in spec with the circuit (measure with a multimeter, 6.3v caps often get less than 4v going to them)
    capacitance- generally half the 'lytic value, but:
    esr- same or lower, which is generally half the capacitance.
    sigpic
    (Insert witty quote here)
    • chth96
      Should I replace polymer capacitor?
      by chth96
      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
      Is this ESR value of polymer capacitor correct?...
      11-18-2022, 04:22 AM
    • Perry Babin
      Derating of polymer electrolytics
      by Perry Babin
      There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
      If they require derating, why would the manufacturer give them their rated voltage?
      This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
      https://www.mouser.com/datashe...
      10-24-2025, 11:57 AM
    • Perry Babin
      How do organic polymer caps compare to liquid electrolytic for reliability
      by Perry Babin
      I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
      If not organic polymer, what would be the caps that could take the most abuse?
      08-18-2025, 04:04 PM
    • Byte_76
      Understanding capacitor ratings
      by Byte_76
      Hi, I have some capacitors that I need to replace on a graphics card.
      I've attached pictures for reference.
      Please help me to understand the ratings so that I can order the correct replacements:
      1. G7 560 2.5E - I believe these are for vcore
      • Is this 560uF and 2.5V?
      • What does the "E" mean?
      • Is there any relevance to the "G7"
      2. ECX 17 560 2.5V - I believe these are on the memory phase
      • Another 560uF at 2.5V?
      • This is on the same graphics card. If the caps are rated the same as those above, why are they a different type?
      05-10-2024, 07:56 AM
    • cj_reha
      Mystery 80s Sanyo cap - perhaps polymer?
      by cj_reha
      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
      01-06-2023, 09:24 AM
