12v 1uo941243c Relay repairable?
  • bohaboha
    • Nov 2012
    • 1009
    • sweden
    #121
    Re: 12v 1uo941243c Relay repairable?
    any advancement ?
    No but a friend mechanic will come tomorrow and look at it let's see if we can solve the mystery. if you can give more advise very appreciated
    • bohaboha
      • Nov 2012
      • 1009
      • sweden
      #122
      any advancement ?
      Hi there came a friend who is a car mechanic but we did not manage to connect he computer to car controls he shall return when it is possible for him. meanwhile so I found this video do you think it can be similar problem that I have? if it is think you can fix the diagram although i think his ECM is similar to my own and i might be able to follow his
      https://www.youtube.com/watch?v=moGszDaCVME
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        #123
        its likely another blown fuse . is the 12v present at the obd2 connector ?
          • 31068
          did you look in the computer yet?
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            #125
            i dont think it can be the ecm blowing fuses as it looks like its providing grounds to the fuel pump etc .
            a blown fuse can stop comms at the obd connector .and can be something silly like lights fuse etc .
            car electrics do strange things like one i worked on and wouldn't start with a blown horn fuse .
            • bohaboha
              • Nov 2012
              • 1009
              • sweden
              #126
              Sorry I no longer have a blown fuse what I have is 3 or 4 fuses that don't get current and all have to do with motor control and ignition and they are nr: 29, 15a/32, 10A/34, 10A and 39. 20A
              • bohaboha
                • Nov 2012
                • 1009
                • sweden
                #127
                something very strange: today i pulled off all the relays in the car even the two in the engine side and turned the key to ignition everything lit up on the panel and even the central lock worked open and close is it normal?
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  #128
                  cant say if normal but i guess it is . did you replace the 50a fuse ?
                  • redwire
                    • 3910
                    The fusible links all looked OK in the picture. I think OP doesn't know how to test them or is making bad conclusions leading to a goose chase?
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      #130
                      yes indeed . only 1 way is to be methodical with these things an study the diagrams to narrow things down .
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        #131
                        all fuses and relays etc need to be installed to proceed properly .
                        • bohaboha
                          • Nov 2012
                          • 1009
                          • sweden
                          #132
                          no wonder you lose power first I had a fuse that was blown then there were four fuses that were intact but they had no power plus a friend car mechanic who wanted to help but couldn't get connected to the car computer and another thing there aren't anywhere the high amps fuses like in other cars
                          • bohaboha
                            • Nov 2012
                            • 1009
                            • sweden
                            #133
                            of course it was just a thing that I wanted to try
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              #134
                              you said the 4 fuses all blew ?
                              • bohaboha
                                • Nov 2012
                                • 1009
                                • sweden
                                #135
                                i'm trying to search methodic. the biggest problem is to know why no current flows to these four fuses as well as no current to the crank sensor i can't find the root to them and i don't know if they comunicate with the ECM or the ECU
                                • bohaboha
                                  • Nov 2012
                                  • 1009
                                  • sweden
                                  #136
                                  no not blow they are ok but when testing i get 0 volt on multimeter and no light on tester
                                  • petehall347
                                    • Jan 2015
                                    • 4427
                                    • United Kingdom
                                    #137
                                    those 4 fuses from before are powered by the fuel pump relay . which gets the power from that 50 amp fuse .
                                    • bohaboha
                                      • Nov 2012
                                      • 1009
                                      • sweden
                                      #138
                                      honestly i don't know where the 50amp and dem steel fuses on the battery look to be fully tested with continuity and volts but don't know if they are 50 amp i'll check extra tomorrow
                                      • redwire
                                        • 3910
                                        From the .pdf in post #50, master power relay K20 gets a 50A feed and seems to be controlled by the ECU.
                                        It has four (output) branches - F28 15A fuel pump, F43 10A, F32 10A, F34 10A are for ECU controlled solenoid valves.
                                        K20 also switches power to the instrument cluster.
                                        For safety or because of fault codes, the ECU might not want to be turning on the fuel pump (master relay K20) in the first place.
                                        • bohaboha
                                          • Nov 2012
                                          • 1009
                                          • sweden
                                          #140
                                          that's what is shown. you said earlier: "I think OP doesn't know how to test them or is making bad conclusions leading to a goose chase?" would you like to help and tell me how i would i test please
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • Crystaleyes
                                            LCD TV Power Supply Board question
                                            by Crystaleyes
                                            First off,
                                            Happy New Year everyone!
                                            Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                                            A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                                            01-01-2025, 09:40 AM
                                          • Nikolai Danylchyk
                                            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                            by Nikolai Danylchyk
                                            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                            Thanks in advance!...
                                            05-08-2025, 06:18 AM
