12v 1uo941243c Relay repairable?
    • Jul 2011
    • 6070
    Re: 12v 1uo941243c Relay repairable?
    Most likely under the hood near the battery
    And a number will be on the top of the fuse or on one side of the fuse
    They will not look like the lower amp fuses
    I just got done installing a car stereo in a semi truck that the engineers thought it was cute to do all the speakers wire green including the power on all the time the ignition switch power the negative side was white
    This only took about an hour for me to figure what wires went to what speaker plus the negative and positive side of each speaker and what wire was power on and the ignition switch power supply with out a wiring diagram but I have many years of experience doing troubleshooting and having the skills that are needed
    • diif
      • Feb 2014
      • 6978
      • England
      #102
      Originally posted by bohaboha
      where are those high amps fuses location d int se any this week realy funny
      I think there is a cover on the battery, it's under that.
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        #103
        PN = negative side
        50 Z = is your control power
        50 A = is your positive side
        it is not that relay next black
        or brown then black that one thank you
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          #104
          those are 30 amp and they are ok
            • Jul 2011
            • 6070
            Check all of the high amp fuses there was a time way back when they used fuse able link instead of a high amp fuse this much hard to find because they can be any where in the car
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              #106
              cant remember if i posted pics of the fuse boxes . .. just starting up the laptop
                • Jul 2011
                • 6070
                Post a picture of the relay that you want to know about
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  #108
                  yes post 41 there is no 50 amp on it
                  • petehall347
                    • Jan 2015
                    • 4448
                    • United Kingdom
                    #109
                    engine bay 1 .there are 8 fuses together .its one of those .
                    left side behind the headlight just to right of battery as yo look at it and behind battery
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #110
                      here it is
                      • petehall347
                        • Jan 2015
                        • 4448
                        • United Kingdom
                        #111
                        when quoting post numbers please add the link by right clicking on post number and copy link then post it .
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          #112
                          ok if you cant find the fuse pull k20 and see if its getting power on one of the large terminals in the socket .
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #113
                            Three 30A ?, the bigger ones are the metal strips.
                            • bohaboha
                              • Nov 2012
                              • 1017
                              • sweden
                              #114
                              https://www.badcaps.net/forum/showpo...2&postcount=42
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                #115
                                excuse me which socket do you mean ? can i use 2 cement10k ?
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  #116
                                  you mean that in addition to the 30amp fuses those metal strips are those high amps fuses?
                                  • petehall347
                                    • Jan 2015
                                    • 4448
                                    • United Kingdom
                                    #117
                                    just measure the voltage on the large terminals where k20 relay plugs in . one should be 12v . the other is going to be shorted to chassis if the fuses have been replaced that blew first .
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      #118
                                      you need to find and fix the short before blowing more fuses .
                                      • bohaboha
                                        • Nov 2012
                                        • 1017
                                        • sweden
                                        #119
                                        i did it allredy ut there i gott power from 2 pins and the fuses are replaced here somes pics. the car have an cautomatic gearbox
                                        • petehall347
                                          • Jan 2015
                                          • 4448
                                          • United Kingdom
                                          #120
                                          any advancement ?
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
