Voltage Regulator
  • stephkre
    • Jul 2009
    • 26
    Voltage Regulator
    I have a voltage regulator on a circuit, part number L7805CV, and I get around 32 volts on the input and 14.88 volts on the output. What I want to know is that enough volts for the circuit to operate on when it says it needs 15V? I know there is some logic that is supplied by this voltage.
    The reason this is concerning me is because there is a bypass cap on the line (the one that goes from the circuit to ground) that was bad. I dont think the low voltage caused it; however, what would be effected by the cap blowing. The device I am working on is a CLSC-12S subwoofer it turns on but has no sound coming out. I checked the transistors on the circuit they seem to be fine.
  • Radio Fox
    • Jan 2010
    • 281
    Re: Voltage Regulator
    I asume you mean an L7815CV.
    14.88v is well within the tolerance of the regulator (14.25V to 15.75V under load conditions).
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
    • larrymoencurly
      • Oct 2004
      • 960
      Don't 78xx type voltage regulators need only 2-3V more coming in than going out?
      OTOH some of them have a power-saving feature that for some reason makes them put out almost the full input voltage unless the output load is at least 25mA (2.5mA? I'm not sure). I think ST brand was or is like that.
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • rddube
        Lenovo L490 Ram voltage circuit malfunction
        by rddube
        Hello friends,
        Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
        I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
        07-15-2025, 04:41 PM
      • artvandalai
        Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
        by artvandalai
        This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
        The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
        11-05-2024, 07:38 AM
      • shakib200
        Ram regulator misbehaving DDR3 VTT voltage Tps 51216
        by shakib200
        The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
        Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
        03-16-2024, 11:33 AM
      • Mark R
        The Overseas Only Kenwood Model KR 790
        by Mark R
        I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
        The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
        09-23-2025, 08:27 PM
