flourescent ballast resistance
    • 31248
    Re: flourescent ballast resistance
    lol
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      The F15T8 mag ballast I'm pretty sure can be used for PL13, though I have a mag ballast PL13 lamp somewhere...
      Also have a PL13 lamp with electronic ballast which I like more because it starts much faster. Except it died because its caps died...and ran out of smallish 20uF 150V caps for the doubler in it to replace it.
      ... now if I used two 3300uF caps for the doubler...
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Originally posted by stj
        i think it's 9w
        i had an idea,
        i will short the 2 pins on the ballast,
        then connect the mains cable to a pcb from a CFL.
        if the lamp lights - the ballast is fucked.
        It requires a ballast to work, otherwise it will burn out.
        In your picture on the lamp it is written Osram Dulux S model 827, it has a G23 base.
        From the datasheet we can see it is a 11W lamp that requires 91v.
        If you feed it mains directly it might explode.
        It does have an internal starter but not a complete ballast like CFL's with E27 sockets for example.
        https://www.elfa.se/en/fluorescent-b...827/p/13354255
          • 31248
          read the post again.
          i was going to drive it with the electronic ballast from a cfl.
          not with mains.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            Finding a 9w cfl ballast shouldn’t be a problem as these are very common. Only thing is, you gotta be damn near on the ball, otherwise too much or too little (wattage mismatch) will damage that lamp. Magnetic or electronic won’t matter.
              • 31248
              fuck the lamp - i have a dozen new ones.
              i just want to verify that the ballast is the problem and not a broken wire or shitty lamp socket.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8340
                Wire a similar lamp or cfl to that ballast.
                • redwire
                  • Dec 2010
                  • 3912
                  I know two-wire tubes are cold-cathode. If you have a HV AC source, like a car ignition coil+555, you can put the HV wire anywhere near the tube and it will ionize and light. BBQ lighter not sure.
                  It's a weird problem, I think either the ballast is pooched having insulation breakdown and it can't deliver the HV start spike.
                  No idea what the starter is about, I think it shorts the tube then opens, which causes the ballast to charge and dump EMF into the tube to light it.
                    • 31248
                    the plastic tube base has a starter across the heaters - it acts just like a fullsize tube.
                    it's actually a good design because it means when you replace the lamp you get a new starter without having to actually get a seperate one.
                    the downside is you cant use an electronic ballast because they need all 4 wires.
                    this is interesting:
                    https://www.greenelectricalsupply.co...ght-white.aspx
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      That options seems cheap and easy enough!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        Actually, that PL13 lamp that I was mentioning, has the integral starter... and it's using an electronic ballast!
                        https://www.harborfreight.com/lighti...ord-63162.html
