Pico osciloscope adc200/50
  • cloepula
    • Sep 2009
    • 49
    Hi to all,
    Today i just bought my first scope.
    Is a digital pc scope, Pico adc200/50. Have 20v max voltage and 25mhz 2 channel. Have one probe 10x, this will be for 200v, but will buy a 100x probe for
    2000v. Will this scope be anough to investigate on smps power supply and somme other electronics like lcd monitors, computers mainboard, and maybe laptop.
    Any help is greatly appricieted and thanks in advance.
  • perfm2
    Wson8 spring pin probe WORKS
    by perfm2
    I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
    I recently ordered one to give it a shot and it actually worked quite well.
    The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
    I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
    This aided greatly in allowing the probe to stay in place...
    03-30-2023, 11:19 AM
  • repair-it
    Need advice testing a samsung power supply board with scope
    by repair-it
    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
    07-12-2025, 11:00 AM
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • EasyGoing1
    Reading input and output of bridge rectifier on the same scope?
    by EasyGoing1
    I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
    When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
    06-26-2022, 12:52 AM
    Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
    I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
    https://www.aliexpress.us/item/32568...3333736563%21s...
    04-12-2025, 10:24 PM
