Hi folks anybody has or knows where can i get a coaxial rf 3 way switch? thanks ;https://www.summitsource.com/Steren-...345-P9459.aspx
RF 3 way switch
Re: RF 3 way switch
Thanks mate.I was able to spot 1 on eBay, and ordered but i think i'm going to get scammed because the switch that i ordered is not the one he is sending me,i already massaged him, will see if i don't have to open a dispute, I should known better.i never trusted Ebay.
although i don't trust much stuff on eBay,but i ordered with pay pal that gives me 180 days to dispute purchase.
https://www.ebay.com/itm/353140571530
the one i want is;Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: RF 3 way switch
I know mate , but the one he was advertising was a 3 way switch. I only noticed when i payed that he switched to a 2 way, i never liked to order from eBay cause i already was taken 1 time, i never learn. Well i already contacted the seller if he doesn't give me the 3 way switch or give me a refund ,i always can open a dispute on PayPal have 180 for it.Last edited by ivtec; 05-04-2022, 03:55 PM.Comment
Re: RF 3 way switch
This happened to a few times where the picture and the description do not match and they sent me what the description says or sometimes it was what the picture was and I always get a refund from EBay so do not worry about it too much but it is still a hassle in either case ( I do order a lot of stuff from EBay it does not happen very often but when it does I have get a little rough with the seller sometimes )Last edited by sam_sam_sam; 05-10-2022, 11:11 AM.Comment
Re: RF 3 way switch
I don't completely fault ebay other than the exorbitant fees they charge sellers, but there are definitely some sellers that use ebay trying to make a quick buck by exaggerating the description...
It is very tough for ebay or any internet company to actually vet each seller unfortunately, and even if they are clean sellers, sometimes sh*t happens and not a systemic abuse issue...Comment
This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 05:30 AM
by Natob82Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
by grimacelordHello,
I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need.... -
by SluggerBI have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,... -
by sam_sam_samPanel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
( needs more cam circuits for the machine to work correctly again )
https://www.ebay.com/itm/275321870186
To
3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
( not 4 positions but the right amount of cams circuits )
https://www.ebay.com/itm/274660439950
I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around... - Loading...
