Kenwood CS-4035 Oscilloscope repair questions
Re: Kenwood CS-4035 Oscilloscope repair questions
So, when going to measure across the cap it became apparent that there was abreak in the trace where the cap had been. Fortunately it was on the Gnd pin side which makes reconenction easier.
It'll have to wait a few hours now though as the day has arrived.
I'll also take some readings at the pin holes with the IC removed and then we can compare how much the hybrid is affecting things.
Back laterComment
Apologies for the delayed response but had an accident and lost a day.
It reads -4.9v
Testing the zener with a component tester comes back as 5.2v
Double checked the voltages just now and that is what they are...What really doesn't make much sense is pin 11 (-8V feedback pot) reads more negative when pin 10 is more positive.
I suppose the next step must be to replace the op-amp?Comment
Just realised that by adjusting the VR1, that pin 11 can go from -0.3, down to -5.00v
Pin 10 is still on -9.5vComment
Quick progress report on the Kenwood KMA 01 Hybrid IC repair
Replaced the TL 072 Op-Amp and now have variation on the -8 voltage.
It currently swings from -9.50 at one extreme, down to -8.86 around the middle region, and back up to -9.50v at the other extremity.
I am hoping that the voltage is high due to no load on the output, however, we do seem to be getting somewhere with this hybrid IC.
The voltage across the capacitor is now 5.03v (the zener is 5.1)
Gonna now move on to the main board and see if whatever is bringing the rails down can't be located and resolved.
Wish me luck!Comment
Excellent news to report...
These Kenwood Cs 40xx series are repairable.
The scope is fixed and working!!!
The reference voltage is now adjusting properly, so just need to calibrate it.
Thanks for the help and suggestions.
Now I have to get the second one done, and I think it only right to document and photograph the repair process of the KMA01 on that unit and post it on BadCaps for future reference.Last edited by Crystaleyes; 05-08-2022, 04:23 PM.Comment
Hi fella.
Yeah, I'm chuffed.
On other threads people had given up on finding the IC's. The general vibe seemed to be to scrap the Kenwood scopes, but it was straightforward on this one, even if I still don't understand exactly how it all works.
These two scopes here have had considerable repairs and tweaks and the short on the main board turned out to be where whoever had changed an electrolytic, had bent a leg (to hold it for soldering) and had almost invisibly shorted that to Gnd.
All good now, just calibration and some noisy switches to resolve.
Big respect and thanks to you and stj. You have literally saved two scopes from the scrapyard
Hello
I have now same problem with -8 V adjust
Pls check power supply ac from transformer
on 120 V ac have 87 Vac - 157 Vac - 9,51 VacComment
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
by DrDosHello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
Observations... -
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
by Mark RI am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...-
- Loading...
