Re: Kenwood CS-4035 Oscilloscope repair questions
Didn't need anything other than a quick blast of heat after running a craft knife along the edges
The pads look a bit oxidised but as I am in the humidity of Rio at the moment it's not so surprising on a 30+ year old pcb, and the 33uF cap now repeatedly measures at 43pF!!!
Just gonna connect up a standard electrolytic to test and I'll see about tidying things up properly if it works
It's a good find, all of my early (1990's) SMT electrolytics did not last for some reason it's like the PCB assembly heat was too hard on them.
I'm not sure what solvent would work to dissolve the epoxy coating, or if heat is enough. The pads are likely fragile if this is thick-film substrate with tinned metal on top. It's surely got fragile thick-film resistors printed on the board so scraping is pretty risky.
Can you try anything like acetone or xylene and a q-tip swab etc.Leave a comment:
Actually, upon closer inspection there appears to be corrosion on the cap and on one of the op amps.
Doing a quick test shows that only IC pin 3 has disconnected, but that is seemingly unconnected anyway.
The cap however, gives a reading of 1430nF, an ESR of 115Ω and 32% Vloss, so that is fooked, and will delicate removalLast edited by Crystaleyes; 05-03-2022, 08:35 AM.Leave a comment:
Cool. Thanks.
Shall give that a go.
Could it be that there is actually no problem on the main board and that the voltages are dropping due to the -8v rail failing under load?
The way I had been thinking is that as something is pulling the voltages down then something is 'failing' as opposed to s dead short, so I was planning to test all the caps, followed by the semiconductors etc.
And here is the IC off the boardLast edited by Crystaleyes; 05-03-2022, 06:52 AM.Leave a comment:
that cap on the hybrid probably needs to goLeave a comment:
Hi Redwire
The module schematic does not look quite right, there should be a path to some reference for the top two op-amps (140V, 5V reg) but not a big deal.
If the HV has problems it will overload the raw +/-10V rail which feeds the +/-8V regs. I'd think about pulling flyback transistor Q8 to stop that.
With no load, many outputs i.e. the +80V and +140V will go too high due to the helper resistors R51, R1. This is normal.
You might have to make up some dummy loads to test the PSU stand alone.
It's a big hassle.
The power supply's rails are all interdependent which makes troubleshooting really difficult.
The -8V rail is the master and if it sags, it will upset the other rails. The +8V (thus +80V and +140V) regulators use the -8V as their reference.
So I would watch the -8V rail for shifting, it's critical that rail does not sag when you plug in the other board.
With no load, many outputs i.e. the +80V and +140V will go too high due to the helper resistors R51, R1. This is normal. There's R5 helper as well for the +8V so it might too go higher with no load. You might have to make up some dummy loads to test the PSU stand alone. It's a big hassle.Leave a comment:
can you post a photo of the kma01 hybrids?
i see a 33uf cap, wondering if it's tantalum or an electrolytic!Leave a comment:
Hola all,
I recently picked up two dead scopes in a job lot. One had missing and blown components as well as a toasted trace on the PSU, whereas the other was complete and not burnt.
Anyway, managed to get both PSU's working enough to switch the scopes on, with the LV rails all more less where they should be, and that is;
+140v
+8v
+5v
-8v
Minus 8v is the adjustable reference voltage, which actually doesn't seem to adjust on either PSU. There is a KMA 01 hybrid IC with a couple of op-amps in it which the voltages pass through.
The problems arise when the PSU is connected to the main board and immediately all the rails drop by around 20% or so.
I'm just wondering how to go about locating the problem? I have a millivolt meter but no working scope.
Would I be correct in thinking that considering how the fault is across all the rails and that all rails are dependent on the minus 8v, that this is where the problem should lie?
There are 37 electrolytics on each main board. I'm planning on testing them first.
Also enclosing the service manual, in case anyone wants a look...
Would be great to get these working.Last edited by Crystaleyes; 05-02-2022, 07:44 AM.Tags: None
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
by DrDosHello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
Observations... -
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
by ferah831208Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.1 Photo
- Loading...
