Kenwood CS-4035 Oscilloscope repair questions
  • Cheito_electroniquito
    replied
    Hello
    I have now same problem with -8 V adjust
    Pls check power supply ac from transformer
    ​​​​on 120 V ac have 87 Vac - 157 Vac - 9,51 Vac
    replied
    Re: Kenwood CS-4035 Oscilloscope repair questions
    i knew the hybrids would be bad.
    in the arcade business Konami uses ceramic hybrids with smd electrolytics on them - and they ALL fail!!
  • Crystaleyes
    replied
    Originally posted by redwire
    Hey that's great news
    I could only see a few voltage readings implying the IC was bad.
    Hi fella.
    Yeah, I'm chuffed.
    On other threads people had given up on finding the IC's. The general vibe seemed to be to scrap the Kenwood scopes, but it was straightforward on this one, even if I still don't understand exactly how it all works.
    These two scopes here have had considerable repairs and tweaks and the short on the main board turned out to be where whoever had changed an electrolytic, had bent a leg (to hold it for soldering) and had almost invisibly shorted that to Gnd.
    All good now, just calibration and some noisy switches to resolve.
    Big respect and thanks to you and stj. You have literally saved two scopes from the scrapyard
  • redwire
    replied
  • Crystaleyes
    replied
    Excellent news to report...
    These Kenwood Cs 40xx series are repairable.
    The scope is fixed and working!!!
    The reference voltage is now adjusting properly, so just need to calibrate it.
    Thanks for the help and suggestions.
    Now I have to get the second one done, and I think it only right to document and photograph the repair process of the KMA01 on that unit and post it on BadCaps for future reference.
  • Crystaleyes
    replied
    Quick progress report on the Kenwood KMA 01 Hybrid IC repair
    Replaced the TL 072 Op-Amp and now have variation on the -8 voltage.
    It currently swings from -9.50 at one extreme, down to -8.86 around the middle region, and back up to -9.50v at the other extremity.
    I am hoping that the voltage is high due to no load on the output, however, we do seem to be getting somewhere with this hybrid IC.
    The voltage across the capacitor is now 5.03v (the zener is 5.1)
    Gonna now move on to the main board and see if whatever is bringing the rails down can't be located and resolved.
    Wish me luck!
  • Crystaleyes
    replied
    What really doesn't make much sense is pin 11 (-8V feedback pot) reads more negative when pin 10 is more positive. That's either a bad measurement or that op-amp has a failed input.
    Just realised that by adjusting the VR1, that pin 11 can go from -0.3, down to -5.00v
    Pin 10 is still on -9.5v
  • Crystaleyes
    replied
    Apologies for the delayed response but had an accident and lost a day.
    Can you measure voltage across the new cap,
    It reads -4.9v
    Testing the zener with a component tester comes back as 5.2v
    Double checked the voltages just now and that is what they are...
    I suppose the next step must be to replace the op-amp?
  • Crystaleyes
    replied
    So, when going to measure across the cap it became apparent that there was abreak in the trace where the cap had been. Fortunately it was on the Gnd pin side which makes reconenction easier.
    It'll have to wait a few hours now though as the day has arrived.
    I'll also take some readings at the pin holes with the IC removed and then we can compare how much the hybrid is affecting things.
    Back later
  • Crystaleyes
    replied
    Originally posted by stj
    btw, TO 072 is probably supposed to be TL072
    Yeah, clocked that when I went to look it up.
    At least it is common enough to replace.
    replied
    Originally posted by Crystaleyes
    I'll bear that in mind for once these are fixed.
    One question, "would the failing electrolytic be enough to fry the op-amp?"
    no idea
    but op-amps fail a lot anyway
  • redwire
    replied
    Can you measure voltage across the new cap, things are acting like the 5.1V zener is pooched or the op-amp driving pin 9 is not working, or 10V zener D5 or Q5 has failed, connecting to pin 9.
    I'm guessing if the 5.1V zener reference is not there (shorted or open), the op-amp can look bad but it's really just making the wrong output based on a bad ref.
  • Crystaleyes
    replied
    i would put an smd tantalum cap across the pads
  • Crystaleyes
    replied
    Can you measure the DC voltages on the SIP module's pins, just a quick check to see if anything looks off. Probably better with the scope board connected to the PSU board.
    I'm presuming that the SIP module is this hybrid IC, and I think you meant to ask to see what 'isn't' off.
    Enclosing the schematic again for quick reference
    The voltages with the main board 'disconnected' are as follows...
    (Schematic listed voltages are in brackets)
    Pins;
    1: +158.8v (+140v)
    2: NC
    3: -0.3v (+0.6)
    4: +7.33v
    5; +3.3v
    6: 0.0v
    7: +8.6v (+8v)
    8: +8.09v (+0.33)
    9: +4.84v (-0.33)
    10: -9.47v (-8v)
    11: -0.65v
    12: 0.0v Gnd_
    Seems tto me that the op amp has failed internally. (Noticable above are pins 1 and 10, which were 142v and 8.2v at the last time of reading)
    Then with the main board 'connected'.. Things get curiouser and curiouser...
    1: +100v
    2: NC
    3: -0v
    4: +0.6v
    5; 3.25v
    6: -0.7v
    7: +2.33v
    8: +3.45v
    9: +3.15v
    10: -5.7v
    11: -1.26v
    12: Gnd_0.0v
    It's perhaps a good thing that I have two of these scopes...
    Speaking of which I pulled the KMA 01 from the 2nd scope and once again the cap measured bad. This one had 77% VLoss and 110Ω ESR
  • redwire
    replied
  • Crystaleyes
    replied
    Unfortunately changing the cap didn't resolve the lack of -8v adjustment and therefore neither any of the voltages on the main board, although I suspect there is something else bringing the voltages down once that board is connected.
    With that board disconnected the voltages are not too far out and the tube has a bright spot in the middle of the screen.
    Anyway, whilst the Hybrid was off the board, I took the opportunity to take measurements based on the schematic, including the zener and all the resistance combinations which all measured fine.
    Therefore, if this problem 'is' on the hybrid, I imagine it to be on the TO 072 op-amp, which judging by the capacitor, shouldn't be such a problem to replace. Just need to find one now...
    Thank you so much though for the support and suggestions.
    Any fresh ideas on where to head next will still be appreciated
    replied
  • redwire
    replied
    The cap is part of the -5.1VDC reference for the -8V regulator. It then makes the master reference for the other rails. Just to save money, use one low drift zener reference instead of a bunch, like one per for each rail. It's also a single calibration at the factory.
    I would use a variac to power it up after, just to make sure the -8V rail is working.
    Back in the 80's these Japanese scopes were copied by the Koreans and made a lot cheaper.
  • Crystaleyes
    replied
    The cap is across the 5.1V reference zener, so I would expect 5.1V if it's working. Note it's -ve wrt GND, a -5.1V ref. so (+) goes to GND.
    Thank you for that. I hadn't noticed that minor detail in the polarity
    So on a more serious tip, why is the cap reversed polarity? What job is it performing being that was around?
  • redwire
    replied
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
  • DrDos
    Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
    by DrDos
    Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
    08-08-2025, 03:16 AM
  • Cemal Odabasioglu
    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
    by Cemal Odabasioglu
    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
    Observations...
    01-14-2025, 03:54 PM
  • Tarot Superstars
    How not to Damage an Oscilloscope
    by Tarot Superstars
    Hello.
    I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
    I want to learn how not to damage it, and I found instructions on the internet obscure.
    They talk about ground, earth, floating ground, this, that....
    But they don't actually say anything anything useful so far.
    I want to know:
    Don't connect exactly this to exactly there or it blows up.
    For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
    I want to know what not to connect...
    08-29-2023, 02:27 PM
  • ferah831208
    help with AMD Ryzen 5 7535hs power rails
    by ferah831208
    Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
    03-09-2025, 01:59 AM
