What is acceptable Vloss for a capacitor?
  • withalligators
    • Jun 2013
    • 267
    Recapped most of the Capxons on a PS board, but monitor is still not working. Didn't replace two Rubycon 35v1000uf caps. Pulled them to test, I have one of those little component testers with the LCD screen. Multiple testing cycles put them at Vloss 0.5 - 0.8, capacitance at ~930, and ESR at 0.00 - 0.01 ohms. I also didn't replace the large main cap. It's 150uf450V, and tests at Vloss = 1.0%, C = 138.3uf, ESR= 0.46ohms. Should I replace these or is that acceptable and I should look elsewhere for the fault? The issue is intermittent, but not working far more than it is working.
    One of the caps on the PS that was visibly bulging had a Vloss of 21%, so that one is obviously bad. These Rubycons that I didn't replace are right next to it on the board.
    See this thread for a more detailed description, if you're curious.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: What is acceptable Vloss for a capacitor?
    vloss (which still is vague in my books) depends on application, there are some applications where even 0.1% vloss is really bad.
    For bulk filtering I'd say anything under about 3% is acceptable, higher than that is dubious, but other people have differing opinions on this...
    • withalligators
      • Jun 2013
      • 267
      Thanks. Where would a power supply fall into the tolerance scale do you think? I sorta doubt this is my problem, but something is causing my main (or Tcon) to not generate an image.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        bulk filtering occurs in power supplies...
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
        • cap__
          Can I replace 15uf capacitor with 22uf?
          by cap__
          "If I wanted to replace an old 15uF/400V capacitor with a new one,
          I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
          11-29-2023, 11:16 AM
