Yet another Samsung 305T post - black screen w/backlight, occasionally works
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always needed a power cycle to work after reseating, which makes me think reseating was probably never necessary, and it was something internal. It worked immediately when I plugged it all in, but eventually gave me a black screen until I couldn't get an image out of it again. No on-screen display of any kind telling me to attach a cable or anything. Just black with backlight shining through.
    I took it apart and see at least one bulging cap on the power board, so I'm going to go ahead and replace all the Capxon stuff as a matter of course, though I can't seem to find any spec sheets for these caps so no idea on what ripple current I should be looking for etc.
    Obviously, this is where I should start, but is there anything else I should be thinking of?
    As far as the caps go, should I just order the best panny / nichicon / decent brand that is the same uf/v and same size?
  • withalligators
    • Jun 2013
    • 267
    Re: Yet another Samsung 305T post - black screen w/backlight, occasionally works
    With help picking the correct caps, I replaced all of the existing Capxons with equivalent Rubycons (there were 2 existing YGF rubycons I didn't replace as well as the large main cap) on the board. Unfortunately the problems persists. I tried multiple shutdowns, restarts, power cycling the monitor, and I got it to work one time after powering the monitor off and adjusting the DVI cable. It remained functional until I turned it off with the front button and turned it back on. Nothing after that. It doesn't seem like a faulty connection. There is also still no "no signal" notification that pops up with no DVI input, just a black screen with the backlights working. I have tried opening it back up and cleaning all the cable contacts with isopro and reassembling. No luck. I can try desoldering the remaining caps and testing tomorrow, but any other ideas? Wherever the error is, it is able to start the backlights, but not the T-con. Bad T-cons usually colorful affairs, but could this be caused by that?
    • withalligators
      • Jun 2013
      • 267
      OK, I finally pulled the two Rubycons and the large main cap. They were at Vloss of 0.5 for the Rubys, and 1.0 for the large main. Not sure if this is acceptable or not. However, while thinking about this, something else popped into my head. This unit is behaving an awful lot like when I'm testing the backlights of a TV by unplugging the ribbon between main and PS. Except instead of just powering on as soon as it's plugged in, it is waiting for the power button to be pressed.
      Any ideas? Should I try baking the main board?
      Realizing I forgot pics of everything:
      https://photos.app.goo.gl/ZNfkfM5gwJ66iohZA
      • rayliu11
        • May 2017
        • 7
        Did you manage to fix this? I have a unit with the same problem, I suspect that it may be the EEPROM either on the TCON or the Mainboard
        • withalligators
          • Jun 2013
          • 267
          I did not solve it. I think it was the daughter board and couldn't make heads or tails of it nor find a replacement. I invested too much time and gave up, nice as it was.
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Yehuda170
            ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
            by Yehuda170
            original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
            replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
            now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
            with original broken screen i can see in device manager touch screen in human interfaces
            but with the new screen it's not showing in device manager
            is it lenovo blocking it? is it driver missing?
            I²C is a headache
            07-14-2023, 01:29 AM
