Question about MOSFET as a switch and a cap?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Talking about using a MOSFET as a switch ... like this (and in this case, the LED is actually a 12 volt incandescent bulb)
    Is there any advantage to adding a cap, like this?
    Does the cap do anything to help guarantee that the gate is off HARD once the voltage has been removed from it?
    sigpic
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Question about MOSFET as a switch and a cap?
    With all the posts we've written about using MOSFETS high side, I'd think you stop running high side.
    Also the MOSFET is still being drawn wrong, you have a P-channel drawn with S-D swapped.
    Perhaps you should just specify your requirements and ask someone to design one for you and we choose the parts.
      • 31260
      replacing the cap with a 10k resistor to help it turn off would be better
        • Jul 2011
        • 6070
        This might be a little of this topic however I want to ask a question about using a mosfet to limit current using a PWM controller so it not completely of topic because I going to follow this post
        I might be interested in doing just what you are talking about here
        1.5 to 24 volts Charging and discharging batteries 0.050 to 5 amps
        This is what I am looking for possibly using a micro controller to control the mosfets
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          yes this is threadjacking, create your own post, but this is not a simple circuit unless you just buy one off from fleabay or ali...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            Yeah if it would ever turn off...
            as it's a p-channel hooked up wrong the body diode will always be on...getting that diode to turn off would be quite a challenge...
            • redwire
              • 3912
              How about the basic mosfet symbols... confusion is plentiful otherwise
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                Yeah whoever set up the "official" MOSFET symbol decided to buck history and made the arrow confusing to people reading schematics. They should have just stuck the arrow on the source terminal and make it follow convention: arrow points in current flow, even if MOSFETs
                or they should have threw everything away and made the arrow point in electron flow.
                my goodness they got vacuum tubes (diodes, triodes, ...) right, arrow/curvature of the cathode electrons are coming from the cathode. But for semiconductor diodes and bipolar junction transistors they made the arrow current flow instead of electron flow... sigh.
                Perhaps the reason for MOSFET confusion was due to history from junction FETs... despite the arrow is drawn on the gate of a JFET normally you don't forward bias the gate, so technically the arrow does follow convention. Translate to MOSFETs it doesn't work...
                Also back to the original topic...
                What does one mean by "turning off hard" ... Usually MOSFET drivers can both source and sink current specifically to shut off the MOSFET fast. So you have a driver problem if you're just leaving the gate floating to shut it off. You can do that with BJTs but not MOSFETs.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  MAN ... it was just a general question ... the schematic symbol was literally one I just grabbed and screenshot just to have a visual to go with the question ... the main focal point of the schematic was about the cap at the gate ... this is not a circuit I'm actually building it was something I was thinking about and then I began to wonder if connecting something between the gate and ground would in any way help sink any potential stray current so that when the voltage at the gate goes low enough, it sinks it down to zero.
                  Thanks, STJ for actually answering the question... that was all I was looking for.
                  sigpic
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Still, be accurate in your schematics. You've been warned multiple times and drawing things wrong will lead to wrong conclusions. Also high side drive has other issues, adding resistors can cause gate failures depending on your voltages.
                    Note that when you shunt the gate to GND you also slow down turn on time, and you also limit your gate drive due to voltage divider issues.
                    As I said for fastest turn on and off time the driver needs to sink and source current. Adding resistors is a bandage.
                    • redwire
                      • 3912
                      The circuit can't work - regardless of mosfet type.
                      P-ch mosfet will never turn off, with 5V on the gate and unknown VCC.
                      N-ch mosfet will never turn on, with 5V on the gate and the source moving up.
                      You can't answer questions about the circuit because of confusion around what kind of mosfet is being used, what VCC is etc. A 12V lamp load is mentioned.
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        • USA, Unsure of Planet
                        Assuming an N-channel MOSFET, for it to turn on the Gate must be several volts more positive than the source. The meaning of "several volts" will depend on the threshold voltage of the MOSFET. Assuming a logic-level threshold (the lowest threshold voltage), the MOSFET in that circuit will barely turn on, with just a volt or two across the "12 volt incandescent bulb".
                        OTOH, if one assumes a 12V Vcc, putting the "12 volt incandescent bulb" in the Drain circuit could work OK with a logic-level MOSFET. With a regular threshold MOSFET the MOSFET might or might not turn on, and if it does turn on it might get rather warm, due to power dissipation.
                        PeteS in CA
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          Yeah it's too bad we have to make assumptions... He could have actually meant putting a correctly placed p-channel device here in which there are still gate drive implications that we'd have to make additional assumptions...and we still don't exactly know what's going on here.
                          He's posted so many erroneous schematics so far that we've pointed out faults in and things don't change... so what can we really infer from these? Pretty much nothing other than perhaps he really should just be working with relays...
                          • redwire
                            • 3912
                            When I was at that stage learning electronics, in tech school, there are two rules that I memorized:
                            For an N-ch mosfet, the gate must have a more positive voltage with respect to the source, for it to turn on. The drain must be more positive than the source (otherwise the body diode conducts).
                            For an P-ch mosfet, the gate must have a more negative voltage with respect to the source, for it to turn on. The source must be more positive than the drain (otherwise the body diode conducts).
                            Once you have these two basics looked after in a circuit design, then you can move on to the other issues - like level-translating, switching speed, on-resistance, heat etc.
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • Jane
                              How do you test MOSFET in laptops ?
                              by Jane
                              I tried to use this method:
                              Testing an N-channel MOSFET:
                              Step 1: Discharge the Gate (turn off the MOSFET)
                              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                              Step 2: Charge the Gate (turn on the MOSFET)
                              Now, place the red probe on the Gate (G) and the black probe on the
                              09-27-2024, 03:31 AM
                            • Natob82
                              Micro Momentary Push Switch?
                              by Natob82
                              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                              12-21-2022, 05:22 AM
                            • grimacelord
                              NEC TurboExpress On/Off Power Switch Replacement Help
                              by grimacelord
                              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                              11-09-2023, 09:49 AM
                            • SluggerB
                              Help making a switch work the opposite way with a relay
                              by SluggerB
                              I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                              I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                              It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                              02-07-2025, 07:57 PM
