Car ECU Chip identification, and find pinout
  • stavi
    • Jan 2022
    • 28
    • HUN
    Hi There,
    I'd like to read/write the contents of the chip. This is a 1995 vintage FORD ECU and IMMO controller.
    Unfortunately, I can't find a circuit diagram or pinout on the chips.
    The serial number uniqe, not factory?
    Can you help me identify the chips or pins?
    many thanks!
    hi, Stavi
    • 31196
    Re: Car ECU Chip identification, and find pinout
    top chip (28pin) has a crystal connected to pins 5 & 6 so it's a microcontroller.
    not sure what microcontroller texas instruments made in 1995
    the lower 32pin chip *may* be an eprom or flash,
    if you had the equipment you could lift it and try to read the electronic ID - but i suspect if you could then you would already have tried.
    • stavi
      • Jan 2022
      • 28
      • HUN
      Dear STJ,
      Thanks for the reply.
      Yes the goal would be to read the bottom eprom.
      I haven't lifted the chip yet. I'm afraid I would be hurt or I couldn't put it back properly. Its functionality would be important.
      And I have a hot air gun solder. But I haven't used it yet to change chips.
      This is new information for me: that the bottom of the chip can be an identifier?
      Hi, Stavi
        • 31196
        the numbers are useless,
        car ecu's always have custom numbers on everything.
        • stavi
          • Jan 2022
          • 28
          • HUN
          I'm sad to hear.
          I leave the topic open to see if anyone who has already encountered this chip live is coming for it.
          It was fitted to many Ford in the ’90s: Escort, Mondeo, Scorpio,
            • Jul 2011
            • 6064
            Originally posted by stavi
            Hi There,
            many thanks!
            hi, Stavi
            You will not be able to find any information about this type of device because it is controlled by the manufacturer and they will not release this information to you
            I have tried in the past with industrial equipment and was told because it was specially designed for the vendor that they could not release any information about the specifications of that part number but would answer questions about product that were not made for any other vendors which I was able to find a comparable part number that would probably work
              • 31196
              the N81c66 microcontroller is a standard part,
              the datasheet will have pinouts and you can trace them to the suspected memory chip
              • jumpstart
                • Mar 2022
                Wx79ahn0w = tms370(immo info).
                N70011fwchca = eprom - (mapping data)
                • stavi
                  • Jan 2022
                  • 28
                  • HUN
                  That seems like a good idea. I'll try.
                  Thank you very much
                  • stavi
                    • Jan 2022
                    • 28
                    • HUN
                    Dear Jumpstart,
                    Thank you very much for your help. This seems like a good solution. I see the RT801f + PEB-1 eprom reader does not know this type of chip, I need to get another type of eprom reader.
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • stavi
                      Canon printhead eeprom chip identification, and find pinout
                      by stavi
                      Hi There,
                      I'd like to read/write the contents of the eeprom chip.
                      This is located on the print head of a Canon inkjet printer.
                      It is likely that this disables the head after printing an xy copy.
                      Unfortunately, I can't identify the chip, so I can't read it either.
                      That is written on it: TO2 (T null? 2), KU
                      Does anyone have any idea what this could be?
                      Many thanks for help...
                      08-29-2022, 01:46 PM
                    • danielgerman681
                      ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                      by danielgerman681
                      Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                      08-27-2025, 01:17 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
