Will ESR of capacitor affect charging time?
  • coolrox86
    • May 2010
    I have three capacitors put in series, each has 1F 5.5V, connected to a circuit with a resistor 33 ohm and 13V supply. Will the value of ESR (Equivalent Series Resistance) affect the time constant RC? That means R = 33 only or, if each capacitor has 30 ohm ESR, value R would equal
    33 + 3 * 30 ?
    Your help will be appreciated. Thanks!
    • 31138
    Re: Will ESR of capacitor affect charging time?
    the lower the esr, the faster a cap will both charge, and discharge.
    i dont know how you calculate it because it will be related the the current capacity of the cap (ripple current)
    • chth96
      desoldered capacitor is self charging until 0.6 voltage.
      by chth96
      I have an 21 inch CRT TV which is not able to power on.
      I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
      It shows 270V on my DMM.
      So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
      Then I desoldered this main filter capacitor from circuit board.
      But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
      I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
      03-28-2024, 08:56 AM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • flat-earther
      Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
      by flat-earther
      I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
      To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
      I have opened the camera and I think there is enough room to add something inside to accomplish this:
      The camera is powered by a 3.7V nominal single cell lithium ion battery.
      So I need to connect another battery in...
      06-08-2025, 02:00 AM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
