Oven DSI igniter cleaning?
  • caphair
    • Nov 2011
    • 1249
    My oven has been randomly turning on when selecting bake. Broil works fine as well as the stove top heaters.
    Checked and noticed the ignitor doesn't ignite. Read that sometimes cleaning the tip can help. Which I did but now it ignites inconsistently
    My question, should you only clean the very tip or entire rod? I'm guessing this works similar to a spark plug as the cage has a little “pointer” that acts as a ground for the spark to travel back to?
    Would bending that little ground tab closer to the rod help with spark if it's still acting up and sparking randomly after cleaning?
  • R_J
    • Jun 2012
    • 9582
    Re: Oven DSI igniter cleaning?
    Clean the very tip of the wire and clean the point of the ground, You can bend the ground tip so it is a bit closer, that should help.
    • caphair
      • Nov 2011
      • 1249
      Is the gap size crucial at all like a spark plug? Or just bend it slightly and should be good to go?
      Another thing does the rod have to be perfectly straight? Mine has a minimal bend to it. Looks a bit wavy but not too noticeable
      • R_J
        • Jun 2012
        • 9582
        It should be lined up with the ground point, it does not have to be perfect and the gap is not that critical like a spark plug
        As the igniter gets used the end gets a bit burnt and this starts to act like an insulation to the spark, cleaning it will expose the metal so it can arc better.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Clean the entire rod. It's also used for flame sense after ignition.
          If it lites & then goes out, it's not conducting to the flame enough=poor flame sense.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • redwire
            • Dec 2010
            • 3912
            It's actually two electrodes - the flame rod and the surrounding half-shell. Both need to be clean to get decent conductivity for flame detection. The pointy end as well for the igniter spark.
            I would use steel wool or 3M scouring pad to clean off soot and oxide etc without leaving debris behind. Sandpaper can leave silicon dioxide (insulator) deposits if you don't clean that off, so they usually say "don't use sand paper!" but I find it's OK if you get the dust off.
            The hardest part is not breaking the porcelain.
            If you still have problems after a good cleaning, it can be the orifice has food on it and the flame is wonky. Or the wiring has a break in the insulation etc.
            • caphair
              • Nov 2011
              • 1249
              Do you mean clean the white porcelain part as well?
              • redwire
                • Dec 2010
                • 3912
                If the porcelain has rust/soot buildup (mostly at the flat end) it causes high leakage current and you either get the spark happening there (not at the gap) or a false flameout detected. So the porcelain needs to be clean too.
                • Fsufan1391
                  LG Oven model LREL6325F
                  by Fsufan1391
                  Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                  04-23-2025, 05:42 AM
                • rumi409
                  LG OLED C1 Pixel Cleaning Made Picture Worse
                  by rumi409
                  ​​​​​​ Hi,
                  I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                  11-15-2024, 01:09 AM
                • bpjl
                  SEF 551.10 - Error starting the reflow oven.
                  by bpjl
                  When starting the SEF 551.10 reflow oven, the following problem occurs:
                  It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                  PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                  10-17-2024, 06:30 AM
                • mkdj
                  Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                  by mkdj
                  Dear all,
                  I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                  I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                  Both N-Channel Mosfets: nothing odd
                  P-Channel MOSFET number 1:
                  source - drain : 117 kOhm
                  source - gate: 96 Ohm
                  gate - drain: 117 kOhm
                  P-Channel MOSFET...
                  08-20-2025, 06:08 AM
                • barry101
                  Apple 820-3662 VCore shorted to ground.
                  by barry101
                  Hi, Would appreciate some help.
                  I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                  Get charger light but no fan spin or chime. No liquid damage.
                  Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                  Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                  With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                  Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                  06-24-2025, 07:34 AM
