Reusing power supply from HP LaserJet RM1-5315
  • DarinC
    • Jun 2021
    • 5
    I'd like to repurpose this power supply into another project. Could someone give me tips on what to connect to get it to power on. I assumed it would be simple like turning on an ATX (connecting green to ground) but I haven't figured it out yet.
  • DarinC
    • Jun 2021
    • 5
    Re: Reusing power supply from HP LaserJet RM1-5315
    I guess its not as simple as I would have imagined
    • R_J
      • Jun 2012
      • 9535
      Based on the picture you provided (from amazon) there is no way to tell. Post clear hi res pictures of both sides of YOUR board and we may be able to trace the circuit.
      There are two optocouplers on this board, one is likely for power supply feedback regulation, the other one could be the one that powers on the supply.
      • redwire
        • Dec 2010
        • 3907
        The PC board has text labels for the wires, such as "3.3V" and "REMO" on the small connector...
        I don't think it ever really shuts off? Unless it goes into some low voltage mode like Canon printers.
        • faraday28
          • Jan 2022
          • 15
          • Indonesia
          Yes you can power this up, but once you plug the Line Input it will running, there is no standby mode. Standby mode in printer usually only on the main board, the power supply is actually running 100% but it doesn't draw much because the main board goes to standby mode.
          Attached picture for explanation what parts on your power supply.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • CMCM
            Russound CA4 Power Supply Repair
            by CMCM
            Hello Everybody,
            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
            The outputs marked 12v and 20v are all measuring only 1v.
            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
            The capacitors physically look clean (no bludgesor leaks) and...
            07-03-2025, 01:12 PM
