I2C Programming - How to ?
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    can someone tell me more about i2c programming wich interface & software is used for.
    And the most important question is:
    Is it possible to read the i2c data from a device, to copy it to another device.
    The part wich i need programm is a TPS658621C
    https://pdf1.alldatasheet.net/datash...PS658621A.html
    here the dataheet, i already found the pins H4 and J2 for SDA & SCL for the connection ,but i dont know wich software and programmer is the right one.
    Thank you for support.
    • 31091
    Re: I2C Programming - How to ?
    are you sure that chip stores anything?
    the "A" version doesnt, it just has control registers that i assume are written when you power up the device.
    • Richi_el
      • Nov 2013
      • 95
      • Koln
      thanks for your support.
      Maybee i have to tell the whole story about it
      i have 5 pcb`s from that device wich are not starting.
      (Industrial device, same like a notebook with touch panel)
      Normally the starting sequence on power supply:
      beginn 0,3Amp raise up to 0,55Amp and then the devie Start by 1,4Amp
      by this 5 pcbs i had some different starting sequencenes and the pcbs are not starting.
      3 x starting sequences goes from 0,3Amp - 0,5Amp raise up to 0,9Amp
      (the TPS658621C goes really hot) and it fall down again to 0,3 Amp
      2 x starting sequences goes from 0,3Amp - 0,5Amp
      so i decided to try to change the TPS658621C with new ones
      The result was that all 5 pcbs are makeing now this starting sequences:
      Start with 0,3 Amp raise to 0,65Amp and fall down again to 0,3Amp
      All 5 pcbs make exact the same starting sequences after change the TPS658621C and also that ones wich goes hot(the TPS658621C) is not getting hot after change but not starting .
      SO my result from that experiment was that the TPS658621C must be programmed and i looked to the datasheet and i saw that 11programmable mods are written in datasheet, and also that this ic is programmable with i2c interface....
      I thought its like a MCU programming maybee, so i was searching for the correct programmer ect.
      Maybee iam wrong, but why all devices have the same starting sequences after change TPS658621C =?
      I never do this before(i2c), but i did some emmc programmings ect.
      Note:
      By one of that devices i had also a problem by starting process:
      starting sequence was 0,3Amp - 0,5Amp and not starting...
      after reflow the TPS658621C (balled) the device started normally
      Thanks for your support
      • Syseng
        Lenovo P14s Gen 5 SVP unlock
        by Syseng
        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
        06-22-2025, 07:44 AM
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • zesko
        MP2886A programming
        by zesko
        I have a board with a dead pwm on mp2886a. I order the chip without thinking about programming, and now I just realize my mistake.
        Someone know if it's 100% needed to program the chip ? And if so, how to program it ? I see some dedicated board and software but, software is a bit tricky to me, the bad part of the job...
        p.s : with the dead pwm chip, the GPU work fine when I disconnect the shorted pwm (6), with the new chip Pgood is 0 and the gpu doesn't start, so I guess it need to be programmed, or it's fake chip..
        p.s 2 : Sorry for my...
        07-28-2025, 02:07 PM
      • hikesync
        XMCQH128A​ Programming issue
        by hikesync
        Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
        06-26-2025, 11:22 AM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
