tda1085 & triac problem
  • techsifnos
    • Nov 2017
    • 7
    • ATHENS
    Hi
    I have a problem with a tda1085c circuit.
    The board has 2 terminal switch with a moving shaft.There are 3 positions. Position 0(motor stopped) posistion 1(right-handed rotation) and position 3(left-handed rotation).At the same time, moving with the shaft a potentiometer to adjust the speed.
    if it has been pressed position 1 or 2 and after turn on the main power switch(230v), everything is ok with universal motor.
    If i turn on the main power switch and press the terminal switch from position 0 to position 1 or 2 the motor starts with high speed and stabilizes in the right speed.The change of direction takes place with relays.
    I have tried to change the potentiometer, but the problem is with the spikes from switches and the triac(bta26-700b)
    Also i have tried to put electrolytic capacitors on switch contacts and gnd, but the problem remains.
    video : https://files.fm/u/qmtjcx3rv
    Could you help me?
    Thank you
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: tda1085 & triac problem
    not sure what the proper behavior should be?
    what is this motor for?
    is the high speed improper?
    Why does this control have a potentiometer on it in the first place, wouldn't it be easier to have a 3-position center off toggle switch and do away with the potentiometer?
      • 31283
      i dont even understand the question.
      is it blowing the triacs?
        Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
        by sam_sam_sam
        Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
        ( needs more cam circuits for the machine to work correctly again )
        https://www.ebay.com/itm/275321870186
        To
        3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
        ( not 4 positions but the right amount of cams circuits )
        https://www.ebay.com/itm/274660439950
        I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
        03-18-2023, 05:12 PM
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • CapLeaker
        Poly VVX-250 VOIP POE problem not booting fix
        by CapLeaker
        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
        11-25-2023, 10:46 AM
      • DrDos
        Alps vintage wafer switch 2 pole 12 position
        by DrDos
        I have the schematic of the kenwood I am working on. It shows the wafer switch which is the on/off - A speakers - B speakers - A + B speaker switch. I don't trust the wiring
        because it doesn't seem to add up for me. If I can identfy at least one of the pins I should be able to rewire it correctly or at least make sure it currently wired correctly but I don't know how to find this out. Pictures are in my thread "trying to refurbish and repair my kenwood kr-6030. I would appreciate the help.
        08-31-2025, 05:03 PM
