Help with smd capacitor test
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    i try to test an smd capacitor out of circuit but get no reading how to do?
  • petehall347
    • Jan 2015
    • 4426
    Re: Help with smd capacitor test
    i guess you found a bad one .. maybe try test a new one .
    • bohaboha
      • Nov 2012
      • 973
      • sweden
      i did it with 11 other but it is same is all of them bad?
      • DjKrish
        • Oct 2012
        • 354
        • SG
        maybe its your meter? try another meter?
          • 30983
          tested with what?
          • bohaboha
            • Nov 2012
            • 973
            • sweden
            Hi stj with multimeter in diode and ohms
              • Jul 2011
              • 6037
              You really can not test capacitors correctly this way you at a minimum have capacitor checker at minimum but really need a ESR capacitor tester to do this correctly
              • bohaboha
                • Nov 2012
                • 973
                • sweden
                you mean that it is not possible with multimeter or digital tweeser am talking about microscopic smd capacitors the ones on the tv screen boards
                  • Jul 2011
                  • 6037
                  No capacitor can not be tested correctly just using diode test or ohmmeter
                  With just a ohm meter or diode test will only tell you if is shorted but nothing else really
                  Now if you have a capacitor tester that shows you UF value that is better than nothing however it does not tell you if the capacitor is good or not for this you need a ESR capacitor tester for this
                  This is the ESR capacitor tester that I use
                  https://www.ebay.com/itm/18423015559...QaAnBZEALw_wcB
                  • bohaboha
                    • Nov 2012
                    • 973
                    • sweden
                    Thank you for the answer your tools is for proffs
                      • Jul 2011
                      • 6037
                      There other versions of this ESR that cost less however the quality with some of them is questionable
                        • 30983
                        our tools cost about the same as a couple of beers in sweden after taxes!
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          You don't need to use that, the cheap "transistor tester" that has been discussed here and elsewhere works just fine and can be had for the same price as the cheapest beer you can find in Systembolaget.
                          • bohaboha
                            • Nov 2012
                            • 973
                            • sweden
                            oh stj,sam_sam_sam and Per Hanson thank you i have that cheap an will test and se.
                            tack Per Hanson glömde bort den den ligger nånstans jag skall söka
                              • 30983
                              beer must have increased in price over the last few years - or the taxes increased!!
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Oops, the quick glance on eBay fooled me: the prices where for empty cases etc.
                                So make it 10 beers then
                                • bohaboha
                                  • Nov 2012
                                  • 973
                                  • sweden
                                  beer are not that expensive as it was even taxes Per Hansson can tell
                                  no not 10 beers Per just around 4 or 5
                                  • bohaboha
                                    • Nov 2012
                                    • 973
                                    • sweden
                                    ok i di some test and i get :28pF from both end of the capacitor and it does not show any esr so i can not know if it is good or not. the result is the same on all 12 capacitors
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • Fuzzy Fix
                                      0.00 ESR reading on a capacitor
                                      by Fuzzy Fix
                                      Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                                      I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                                      Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                                      07-26-2024, 12:05 AM
                                    • bauto601
                                      KDM 480W PSU upgrade succes! (opinions?)
                                      by bauto601
                                      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                      A "nice" YoungYear unit? - Badcaps
                                      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                      12-26-2023, 03:05 PM
                                      1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                      I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                      This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                      12-29-2024, 07:18 AM
                                    • Crrose
                                      How to test circuit board battery connection.RS-4i sequential stimulator
                                      by Crrose
                                      Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
                                      03-21-2023, 03:55 PM
