usb 2 and 3 cable wiring differences ?
  • petehall347
    • Jan 2015
    • 4450
    as above what is so different in usb compared to usb3 ? its just i need use an extension for usb 3 and only have usb 2 ones . i tried painting it blue and no dice .
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: usb 2 and 3 cable wiring differences ?
    There's an additional two pairs of wire and another ground contact in the connector that needs to be connected... so yeah need special connector and more wire pairs specially shielded for high speed.
    • petehall347
      • Jan 2015
      • 4450
      hand in pocket time as pretty sure i don't have any blue ones . i have have just about every other sort of connector leads .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        Should be able to look at the usb3 plug and see there are 9 contacts - 4 on the outside, and 5 inside...
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Patch2
          Cable Repair
          by Patch2
          I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
          01-02-2025, 06:04 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • fweonea
          HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
          by fweonea
          While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
          I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
          01-16-2024, 11:35 AM
        • marce002
          Help me make charger USB C cable with no cc pins!!
          by marce002
          Hi all, please
          I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
          How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
          NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
          here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
          thanks in advance!!
          11-17-2023, 09:16 AM
