What's the use use of these things?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I have attached image to this post.
    I have marked some cloth sleeves with nr 1 and some plastic cover with nr 2. Does anyone know what is the use of those and are they required? These sleeves with nr 1 are not shrinking tubes. but since they are already around insulated wires, I cant think of any practical use so I thought I would ask those smarter than me. Other thing is plastic cover on top of transformer. Would something happen if it were removed? If the metal case is grounded and some parts of transformer's outer metal frame touch the metal case, would some current flow to case?
    Also one question is that the yellow part of that transformer frame is 5.5 cm from left to right. Based on size of that high frequency (likely around 100kHz) transformer (13:1 ratio) how much power would be reasonable to expect it to deliver with out forced cooling by fan? In my case 50W load got it to around 80C and 70W load got it around 100C. Is it normal for such relatively small load to generate that much heat in transformer?
    • 31015
    Re: What's the use use of these things?
    fiberglass sleeving.
    you use it if you think something in or against it could get hot.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4953
      • New Zealand
      It can also be to protect against vibration/abrasion damage.
      -David VanHorn
      • LearningToRepair
        • Jul 2020
        • 35
        Tnx for info. Does anyone also know something about transformer related questions and whats that thing on top of it?
          • 31015
          it's exactly what it looks like.
          i suspect they are either trying to control airflow or stop dust getting trapped between the transformer and case-top
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 04:40 PM
