LED Resistor Calculations ...
+ More Options
Latest Activity
  • EasyGoing1
    replied
    Re: LED Resistor Calculations ...
    Also, with everything powered up for over 10 minutes, the aluminum back plate is at 117 degrees C ... that's pretty damn hot! And at 12 volts, it's drawing 1.3 amps.
  • EasyGoing1
    replied
    Re: Rim e: LED Resistor Calculations ...
    Originally posted by diif
    Appologies, I'm on my phone as my Internet is down and autocorect changed to "shouldn't"
    Of course it should be soldered.
    So I just received the aluminum boards which are the same as the pics I've been showing you in terms of the copper layer etc.
    And something I noticed about them right off the bat trying to solder components onto them is that I had to hold the heat gun on the board for a LOOOOONG time before the solder even melted but then once that first one melted the rest just melted instantly with only a second or two of applied heat and then of course, the entire board was hot as hell when I was done so I rinsed it under some cold water ...
    Then, then I used the iron to solder two wires to it on the pads that supply power, I could not melt the solder on the whole pad at the same time so there is DEFINITELY heat transfer happening in a serious way from each and every pad to the aluminum somehow ... don't know how exactly ... but there is no question that it's happening.
    I don't think I'm going to need to use that design I have where I connect the aluminum to the ground plane with VIAs ... I think it will be overkill and unnecessary.
  • diif
    replied
  • EasyGoing1
    replied
    My panel has LEDs in series and parallel, why wouldn't your design work ? No, it doesn't need to be soldered, but it will conduct heat far better soldered to a large copper pad.
    OK so, you're getting more confusing ... in your last post you said, "The thin bit you see is the only part of the board apart from near the edge there is no used copper, when i say used, I mean used for dissipating heat, power is coming top to bottom." (whatever 'Top to bottom' actually means...)
    I read that to mean that no copper was used on the board for dissipating heat.
    BUT NOW you say, "No, it doesn't need to be soldered, but it will conduct heat far better soldered to a large copper pad."
    So which is it? Do we use copper for dissipating heat or don't we?
    MY first run of this board had all of the center pins sharing a single copper plane. Little did I know at the time, was that the center pin on the LED was also the Anode. So they didn't work until I drilled out the vias that connected the center pin to the copper plane on the back of the board.
    Why can't I seem to get a straight and complete answer as to the proper way to design a fucking board for LED arrays? If there is a known correct way to do this, where is it documented? I'd probably get a lot more out of reading something specifically intended to instruct engineers as to how to properly design a PCB that contains a ton of heat-generating LEDs.
    My current design uses a copper plane as well as an aluminum backing to dissipate heat but not heat that comes from the soldered pin on the LED, but rather the heat passed from the LED onto the copper plane through the solder mask then from the cooper plane onto the aluminum backing, and I added vias to connect the copper plane to the aluminum and I'm waiting to find out if they can actually do that or not. I don't know how they construct vias so I'm not sure.
    Now, if I were to have each LEDs center pin soldered to the board, I would have to electrically isolate each "heat dissipation zone" for each LED so that none of the anodes are connected to each other. And for the life of me, I can't see how that would be a whole lot better than what I came up with because in that design, the heat would only be dissipating through a smaller piece of copper rather than sharing the entire size of the board for heat dissipation.
    But I might be wrong in my thinking where that is concerned perhaps it is better to have small areas of copper attached to the LED for heat dissipation but then that begs the question, how does the heat from those smaller copper regions get to the aluminum backing? It would have to be through standard heat transfer by way of some thin layer of material between the copper area and the aluminum.
    NOW, if they are able to connect the copper area to the aluminum with via's then I can guarantee you that my design of passing heat through the solder mask then to the aluminum by way of dispersed via's will run a hell of a lot cooler than soldering the center pin to smaller areas of copper then moving heat through an insulating layer ... as my design would allow the heat to move along connected metallic paths. Like this ...
  • diif
    replied
  • EasyGoing1
    replied
    I'm not sure why you're capitalising certain words but this photo should help explain.
    The thin bit you see is the only part of the board apart from near the edge there is no used copper, when i say used, I mean used for dissipating heat, power is coming top to bottom. The anodes and cathodes are all joined in big wide copper strips.
    The centre pad on your LED should be soldered it's connected to the anode.
    "The anodes and cathodes are all joined in big wide copper strips" - so in my design, this is a problem ...
    Here is the schematic for my LED panel... as you can see, if I just connected all of the anodes and cathodes ... it would not work at all.
    Also, the center pin does NOT need to be soldered for the LED to work. The two ends of the LED are all that are necessary for the things to light up.
  • diif
    replied
  • EasyGoing1
    replied
    No not like that, I still see traces, the heat is trapped under the LEDs and can't go sideways.
    Draw thick lines from almost the top to the bottom that is your + pad the a tiny gap then another for the - and so on. The only thin trace will be the - round the edge going pack to the - input.
    With LEDs you're routing heat as well as electricity, heat is your primary concern.
    Originally posted by eccerr0r
    And still the NC pad are all connected together? Or are you using a different chip now?
    note: depending on soldermask insulation is not a good idea...
    OK, I colored the copper layer which is all electrically GROUND in yellow. Everywhere you see an X. the center pin of the LED is pressed against the SOLDERMASK on the board... the center pins are NOT soldered to the board. THEN, the back of the board is aluminum...
    Tell me how to dissipate heat better than this?
  • eccerr0r
    replied
  • diif
    replied
  • EasyGoing1
    replied
    You want the whole of the front to heat up evenly, remove those traces and have the + and - pads the full width of the board.
    You mean like this?
    The copper layer which is all on the GND net, is underneath each LEDs heat dissipation node without any exposed copper so it will heat the entire copper plane that is GND electrically then presumably that will pass to the aluminum for dissipation...
  • diif
    replied
    Originally posted by EasyGoing1
    Could you be more specific?
  • EasyGoing1
    replied
    I think you should look at your design to better take advantage of the copper front.
    replied
    i think you should look at your design to better take advantage of the copper front.
    +1
  • diif
    replied
  • EasyGoing1
    replied
    I have a dead GE A19 bulb I need to take apart and do failure analysis...
    You're talking about a replacement light bulb? What's the point? Those things are cheap now a days.
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Aluminum PCB just means the backing is aluminum, of course, this will not function as a regular PCB, so there's a layer of dielectric on the aluminum. Then there's another layer of copper over the dielectric which gets etched. Heat transfer still needs to go through the thin dielectric layer, so it's not as good as being soldered straight to the aluminum but it's better than FR-4.
    So I did some re-design on the panel, and I also made a 12-volt version ... everything on one layer without any center pins on the LED at all on the board, and I had originally had some through-hole components but when I had PCBWay quote them, they wanted over $300 ... so I made everything surface without any through-hole components and am waiting for that quote... apparently, when you spec aluminum for the board, it takes longer to get it quoted, but if the quote remains at the price it was when I put it in the cart, then ill order them up and should end up with a better panel that I have now.
  • redwire
    replied
    Most high power LED dies have two bonding wires, with the die (substrate) glued or soldered to the cathode leg.
    OP's having a third pad seems like it's just cheap or something.
  • diif
    replied
    Yes, with large copper planes on the front and the back solid aluminium the whole PCB becomes a heatsink.
