Switch selection
  • notallbad
    • Oct 2012
    • 1190
    Switch selection
    Looking for a replacement momentary switch for a 230v power tool but the only type I can find that not only looks the same but will also fit into the housing is rated 20A @ 12v and 15A @ 24v.
    Will this be fine?
  • notallbad
    • Oct 2012
    • 1190
    Re: Switch selection
    Just realised it may not be a 240v switch, will have to wait until I have the tool to investigate further.
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      Most power tool switches are not simple switches, but have regulator inside their housing.
      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
        • Jul 2011
        • 6057
        If it is a battery operated tool that variable speed most of them have small circuit board on the switch housing or it external of the switch
        But the switch is not a normal type of switch it has multiple switching contacts that have certain travel points for the different speeds
        I have use the speed controllers from battery operated tools ( for other purposes ) before but you need to be careful not to hook up the battery power in the wrong way because it not forgiving at all and you will let out the factory smoke and then it all over
        I also seen the ones that are 120 volt ones but they are a different puppy altogether and they are not very easy to repair because of having a hard time getting the parts ( sometimes the motor winding are either shorted or the winding is open depending on how the switch failed )
          • 31137
          pictures, or it didnt happen!
          • notallbad
            • Oct 2012
            • 1190
            This switch is def a standard momentary (normally open) type switch. Its a straight forward off/on state, a pivoted pull handle activates the tool and cuts out when released (safety feature).
            The tool is 230v mains operated but I am yet to investigate the wiring / circuitry arrangement to confirm power at the switch.
            Thanks for your input guys, appreciate it!
            • Natob82
              Micro Momentary Push Switch?
              by Natob82
              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
              12-21-2022, 05:22 AM
              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 05:30 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • rex98
              HP DMI Tool
              by rex98
              HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
              DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
              The DMI Tool given here are for personal use only.
              DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
              You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
              from it, and that you please credit the author...
              07-02-2025, 05:51 AM
            • grimacelord
              NEC TurboExpress On/Off Power Switch Replacement Help
              by grimacelord
              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
              11-09-2023, 09:49 AM
