Marks on the PCB
  • Askic
    • Sep 2018
    • 187
    • BIH
    Marks on the PCB
    Hello guys,
    what would you say if you see marks on the PCB like the one shown in attached pictures?
    Are those traces from liquid or something else?
    Thank you!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Marks on the PCB
    Crusty looking capacitors, green vias, looks like liquid to me.
      • 31283
      the green vias are solder-mask to protect the conductive paint.
      the white could be a sign of moisture or just poor factory de-fluxing.
      • Askic
        • Sep 2018
        • 187
        • BIH
        This board was in spare parts stock for about 10 years. It wasn't properly sealed but never used. I'm gonna use toothbrush and some isopropyl alcohol to clean it.
        • questore
          nvme and wifi error after liquid metal spill
          by questore
          Someone brought me a liquid metal damaged motherboard.
          First I have removed alll liquid metal from the board.
          0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
          Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
          There are 2 things that not working.
          1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
          2. nvme devices are not detected on either of the 2 slots....
          11-11-2025, 01:16 AM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
        • kurland
          Strange liquid on damaged GTX1080 card
          by kurland
          I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
          As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
          Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
          11-17-2020, 07:14 PM
        • av4x
          Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
          by av4x
          Good morning, everyone!
          I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
          First up is a Fujitsu Lifebook U7511.
          It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
          Model: Fujitsu Lifebook U7511
          CPU: Intel Core i5-1135G7
          GPU: Intel Iris Xe Graphics
          RAM: 16GB DDR4 - 3,200 MHz
          PCB manufacturer: ASKPCB?
          PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
          Damage: Liquid damage
          The liquid probably...
          11-01-2025, 03:09 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
