Need help diy a power bank
  • mikey5791
    • 521
    • Malaysia
    Hi friends,
    Got this simple power bank of 8800mAh capacity but the inside battery seems to be failing. It is not taking any more useful charge. The dmm measured the battery reading about 0.17vdc. The input is rated at 5v 2.0A. I was thinking about replacing the failed battery with some extra batteries from my used laptop battery pack.
    The laptop battery pack is AL15A32( rating 14.8v 2350mAh) consisted of 4 series joined 18650 type li ion battery. However, one of the battery showed only 0.15vdc but the remaining 3 are still within 3.77v to 4.21vdc. Is it possible and safe to cut off the 3 li ion battery and solder to the power bank connector and try charging with an off the shelf 5v 1.5A phone charger? I wish to rebuild this set of battery pack as a power bank and hope for any advice if this can be done.
    • 31287
    Re: Need help diy a power bank
    you have 2 questions there.
    lets deal with the laptop pack first.
    get rid of the small board from the battery pack,
    solder wires to the tabs of the almost dead battery.
    then connect those wires to a 5v supply - like a usb psu, BUT put a 75ohm resistor in series with it.
    that will very slowly charge the battery back up over a day or 2
      • Jul 2011
      • 6070
      These two are no good remove and do not use them or even attempt to try to charge them—> Doing this could be very dangerous undertaking when the voltage is this low more than likely are shorting internally and would charge anyway
      I personally would not attempt to charge any li ion battery that is lower than 1.0 volts however you could try to charge batteries over one volt using the method below as well but to do this use a lot of caution watching the temperature of the battery unit the battery voltage come up to 2 volts
      Now STJ has in his post to charge a battery that is above 2 to 3 volts I would totally recommend and would agree with ( on a side note I would use the battery bank pack board with current limiting resistor like STJ had in his post earlier)
      Now you can use 18650 in this battery bank pack but I am going to caution you about pouch type li ion batteries unsolder the tabs from the board or cut the tabs do not be temped to rip it from the board this will probably damage the board and the battery if you were to want to reuse the battery or charging board if they are still good
      Now if you decide to use the 18650 battery cells from the computer battery pack cut the tabbing from the protection board and to separate the cells from each other you can pull them apart or cut them in the middle of each cell so you have soldering tab to join the battery cells together
      But you would need to find a case that will fit the battery or batteries and charger board and yes you can use more than one cells wired in parallel but I will caution you that if you are going to rely on the fuel gauge on the battery pack limit the number of cells to the maximum battery amp hours that posted on the data plate on the case of your battery bank pack
      When you hook the battery to the battery charging board you might notice that you have no battery power from the board this is normal on some board just hook it to your charger and this will reset the protection circuit on the board and it should function after you do this
      I hope this help
      • mikey5791
        • 521
        • Malaysia
        Hi stj and sam x3,
        Before i start this project, i will try to find a bigger case for the new battery pack.
        I will look into all the suggested comments.
        Thank you for reply.
        • razenxd
          How can I charge that battery pack?
          by razenxd
          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
          Now, I have noticed a few things.
          The "dead" battery, while connected to charger and NOT Charging will...
          12-05-2024, 06:11 AM
          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
          by sam_sam_sam
          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
          So I have put them on the battery testing machine to drain each battery cell down to...
          09-04-2022, 04:45 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • kodox
          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
          by kodox
          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
          what i've done:
          - flashing...
          12-29-2024, 02:49 AM
