How could I find a FET with specific specs?
  • EasyGoing1
    replied
    Re: How could I find a FET with specific specs?
    Originally posted by eccerr0r
    Never used a C64 but as a 6502 I don't think that's horribly bad. I do have my qualms with 6502 however, not a great processor either but much better than PIC 8-bit...
    6502s are fast however. Beats the Z80 which I've preferred, but 6502s murder the Z80 MHz for MHz.
    This new laptop I got has 32 gigs of RAM in it...
    My first computer, the C=64 had 64k of ram...
    So TODAY, my computer has 500,000 times more ram than my first one.
    That's pretty phenomenal to me.
  • eccerr0r
    replied
  • EasyGoing1
    replied
    No, I generalized all PIC 8-bit microcontrollers into the same bin... the trash bin...
    That's where my Commodore 64 went several decades ago and I still don't regret it ... even if these weirdos are obsessed with the C=64 making a come back... I don't live for the past ... I'm happy to be done with it.
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Are Microchip/General Instruments PIC8s dead yet?
    If so, good riddance.
    If not, ()#$*#(@#*(@ their memory management.
    Could you have meant the PIC18 Microcontroller?
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Originally posted by stj
    if your going from AVR to Pi or STM32, remember your i/o is 3.3v
    good for displays - you dont need resistors,zeners or buffers anymore - but may need a bit of attention with some sensors
    I've had two Arduino Due's ... and managed to foul them up pretty nicely because i wasn't being mindful of the 3v limit. However, these Teensy 4.0's I've managed to not damage and they are 3v so ... this old dog can learn some new tricks.
    replied
  • EasyGoing1
    replied
    I ended up carefully checking the compile results when converting object files to hex each time it completes, if it had to program a location that's beyond the end of the device, don't bother programming it, back to the drawing board, cut a few bytes out.
    I had 2KB (1024 16-bit instructions) in the AT90S2313, and will be da**ed if I had to waste more of that 1024 bytes for the arduino infrastructure.
    Oddly enough I had an issue with my AT90S4433 where I had a software clock, it was drifting real bad - several seconds per hour. I sort of knew why - I was using the hardware resources kind of messily because, well, I ran out of hardware resources. However I hacked my clock software to match the hardware cheat I did...and wow, only a few seconds off per month. Not bad for a breadboard that I can't properly tune the crystal.
    Alas it used up more precious bytes in the 4KB (2K 16-bit instructions) to compensate for the hardware problem...
    Sounds to me like you're a lot more comfortable with low level programming than I am. My experience with machine language was like 1992 with a Motorola 6800 chip at the college lab... I do remember programming it with hex... the keyboard had 0-9 A-F and if you messed up, there was no delete ... you started over.
    Beyond that, I think maybe twice I had to get down to the hex level when trying to hack something but that is the extent of my experience with low-level coding. I just was never very comfortable in that space for some reason. I admire people who can do it ... and who UNDERSTAND it ... I mean ... that is the highest level one can achieve in terms of mastery control over a microprocessor.
    Yeah, the Arduino Nano, at least ... did not impress me with a larger project. It's just fine for simple to moderately complex tasks.
    I ordered two of those new $4 Raspberry Pi Pico's with a dual core ARM Cortex M0 ... it seems like a lot of microcontroller for $4 when you add in all the GPIOs and ADCs and all the other goodies... I just wanna multi-thread on an MC before I die ... lol ... this thing has two actual cores ... I darn well better be able to multi-thread with it ... or I'm gonna troll their forums! LOL
    I read the first page of the datasheet for the AT90S4433 - seems like a decent little MC - not sure how long its been since it was first introduced, but you could do some damage with that controller for sure.
    A few things about MC manufacturers that both bother me and have me confused ... why aren't 12 bit ADCs standard on all modern microcontrollers? Seems to be more of a novelty than it should be! I mean who wouldn't want to read a voltage with 4096 steps of resolution compared to 1024? Best I can figure is that the cost of including it must be such that it ends up on the cutting room floor.
    The other thing is why not include RTCs ... but I'm starting to see that happen more often in newer controllers. The Teensy 4.0 has a nice one with pins for battery backing it. That Teensy 4.0 can actually do some sick tricks with audio in real-time ... I think, depending on what you're doing, it can process like 16 channels of 192-bit uncompressed digital audio simultaneously and the engineer who designed it included a ton of various audio functions right in the chip. He even wrote this really weird app that lets you drag and drop objects for audio processing, cross-connecting channels and a whole slew of things ... it's like a DJs wet dream.
    I have no interest in any of that except that I do want to make my own EQ someday... Mainly just to do it but also to better understand what digital EQs do at a lower level.
    Mike
  • eccerr0r
    replied
    Why would I use it, I didn't need it then, so why now? Just more overhead...
    replied
    As I've been using AVRs like the AT90S2313 and AT90S4433 (which don't support arduino
    https://github.com/SpenceKonde/ATTinyCore
    btw, i prefer STM32 chips - lots more memory for the same price as AVR.
    BluePill, and Nucleo boards.
  • eccerr0r
    replied
  • EasyGoing1
    replied
    I'm sure you've run up to the memory limit before when programming microcontrollers ...
    Once I built a CO2 sensor for a friend of mine who built his own kiln inside his garage. I used an Arduino Nano, a 16x2 LCD display, a CO2 sensor, a temperature sensor, a battery-backed real-time clock, a CF card reader/writer, and a Bluetooth module for wireless programming/reprogramming. I even sprung for the custom made PCB from China.
    I was constantly having to find ways to squeeze my code so that I didn't use up all the memory. This is where a deeper knowledge of C++ can really help someone, especially with variables when you can figure out how to keep your byte usage rigidly defined, it makes a HUGE difference. There is also an area of memory that you can use with some datatypes - but I forgot now how that all worked.
    What was and still is frustrating with that Nano, is when your code exceeds 80% of available memory ... your code can do unpredictable things ... just odd things like not running loops or like in the CO2 sensor project, once I exceeded 80% or program memory, I would get garbage characters on the screen, so I would have to use direct memory access using chars instead of Strings and it became a real pain in the ass.
    It also had horrible time drift in the RTC, but I was able to figure out how many seconds it drifted per hour and so I set it to the current time, then wrote to the flashcard the current Unix time (milliseconds since 1/1/1970), then if it ever had to be disconnected from power, the next time it booted up it would read the RTC and compare the current Unix time with the last one that was written to the CF card, and depending on how many hours it was different, it would add in the known drift and get right back to being within seconds of accurate. If the number of drift seconds per hour that accumulated from the last power-off was excessive (like if it were powered off for weeks or months) and the total of offset seconds exceeded an hour, then for each of those it would add an additional drift offset...
    Been almost two years and he tells me that the time is correct every time it boots up so I obviously got that part right, but what a shitty RTC. Never used those again. It did rely on an external crystal, so it could have been the cheap Chinese crystals that I bought but I've since gone to an RTC that has everything internal to the chip and they work perfectly.
    If the Teensy 4.0 would have been available back then, it would have been a far better choice. Compared to the nano, program memory space would be like going from a backyard shed to a Costco warehouse.
  • eccerr0r
    replied
    avrdude is also used for burning via SPI, or at least I also used it for raw AVRs. The thing that got me was when I was looking at the difference between programming straight AVR and using arduino is that there was a piece of code segment that needed to reside on the AVR. As I've been using AVRs like the AT90S2313 and AT90S4433 (which don't support arduino), that little code segment hurts so I didn't investigate further.
  • EasyGoing1
    replied
    I've been hearing that arduino has a special software loading mechanism that doesn't require SPI access to burn new code onto it. This clearly uses some resources to complete this task. The in-circuit debugger must use some resources as well, at the minimum a pin or so, and not entirely sure how it handles stuff like single step.
    You can turn on full verbose mode in the Arduino IDE settings so that when the code gets uploaded, you can literally see EVERYTHING that happens in a command-line format ... it's like watching it open a shell, then seeing what it does when it compiles and uploads the code.
    I do know that it uses avrdude to handle most if not all of that entire process.
    Here is an example of the output when those settings are set (I had to snip some of it or this post would have been too long to post):
    Code:
    /Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware <snipped>
    /Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/michael/Library/Arduino15/packages -hardware <snipped>
    Using board 'nano' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
    Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
    Detecting libraries used...
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/sketch/delete.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
    Generating function prototypes...
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/sketch/delete.ino.cpp -o /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
    /Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/preproc/ctags_target_for_gcc_minus_e.cpp
    Compiling sketch...
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/sketch/delete.ino.cpp -o /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/sketch/delete.ino.cpp.o
    Compiling libraries...
    Compiling core...
    Using precompiled core: /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_cache_191331/core/core_arduino_avr_nano_cpu_atmega328_51f02b7210b938436b779d1c032618e1.a
    Linking everything together...
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.elf /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/sketch/delete.ino.cpp.o /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/../arduino_cache_191331/core/core_arduino_avr_nano_cpu_atmega328_51f02b7210b938436b779d1c032618e1.a -L/var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547 -lm
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.elf /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.eep
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.elf /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.hex
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-size -A /var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.elf
    Sketch uses 3910 bytes (12%) of program storage space. Maximum is 30720 bytes.
    Global variables use 204 bytes (9%) of dynamic memory, leaving 1844 bytes for local variables. Maximum is 2048 bytes.
    /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -V -patmega328p -carduino -P/dev/cu.usbserial-1441230 -b115200 -D -Uflash:w:/var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.hex:i
    avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, [url]http://www.bdmicro.com/[/url]
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/michael/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port          : /dev/cu.usbserial-1441230
         Using Programmer       : arduino
         Overriding Baud Rate     : 115200
         AVR Part           : ATmega328P
         Chip Erase delay       : 9000 us
         PAGEL             : PD7
         BS2              : PC2
         RESET disposition       : dedicated
         RETRY pulse          : SCK
         serial program mode      : yes
         parallel program mode     : yes
         Timeout            : 200
         StabDelay           : 100
         CmdexeDelay          : 25
         SyncLoops           : 32
         ByteDelay           : 0
         PollIndex           : 3
         PollValue           : 0x53
         Memory Detail         :
                     Block Poll        Page            Polled
          Memory Type Mode Delay Size Indx Paged Size  Size #Pages MinW MaxW  ReadBack
          eeprom    65  20   4  0 no    1024  4   0 3600 3600 0xff 0xff
          flash     65   6  128  0 yes   32768 128  256 4500 4500 0xff 0xff
          lfuse     0   0   0  0 no     1  0   0 4500 4500 0x00 0x00
          hfuse     0   0   0  0 no     1  0   0 4500 4500 0x00 0x00
          efuse     0   0   0  0 no     1  0   0 4500 4500 0x00 0x00
          lock      0   0   0  0 no     1  0   0 4500 4500 0x00 0x00
          calibration  0   0   0  0 no     1  0   0   0   0 0x00 0x00
          signature   0   0   0  0 no     3  0   0   0   0 0x00 0x00
         Programmer Type : Arduino
         Description   : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget     : 0.3 V
         Varef      : 0.3 V
         Oscillator   : 28.800 kHz
         SCK period   : 3.3 us
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.00s
    avrdude: Device signature = 0x1e950f (probably m328p)
    avrdude: reading input file "/var/folders/54/5r84qmzx1ys3694t14j0zh940000gn/T/arduino_build_673547/delete.ino.hex"
    avrdude: writing flash (3910 bytes):
    Writing | ################################################## | 100% 0.69s
    avrdude: 3910 bytes of flash written
    avrdude done. Thank you.
  • EasyGoing1
    replied
    Thanks but is there one for getting started with the nano because this what I would to learn because of engraving machine controller board that I would like to modify the program that in especially for PWM to work correctly with the laser and spindle motor controllers that what I am after at this point
    Well, here is the first question I have: do you have the code that the Nano is loaded with currently?
    replied
    Originally posted by EasyGoing1
    Sam, check this out ... I think this might be the first DUAL CORE microcontroller for less than $5 - ever ... that I know of anyway. I haven't looked into it in depth yet cause I just saw this but multi-threading apps should be completely possible with this little gem.
    https://www.raspberrypi.org/products/raspberry-pi-pico/
  • eccerr0r
    replied
    "arduino" is software. Nothing on hardware block diagrams have anything to do with it, hardware can't tell if it's running arduino infrastructure or not. Nothing special about it except that
    - it must use memory. Without arduino you can make bigger programs.
    - it must use some resources. Without arduino you can control all resources.
  • EasyGoing1
    replied
    My problem is I do not know where to start looking for this information is it possible to point me in the right direction
  • EasyGoing1
    replied
    To be honest 450Hz should be fast enough to not see much flickering unless your software is glitching and introducing a beat pattern... so are you actually seeing a beat pattern without the capacitor? What frequency is it beating?
    So I successfully increased the PWM frequency of the ATTINY85 ... at least I think I did ... my phone wont detect the flickering anymore but my scope seems to have given up the ghost ... thinking of starting a new topic on scopes cause I want to get a better one this time ... not this cheap $80 Hanetek USB pile of crap.
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • nunofcc
    Logitech G29 Help request to find smd transistor reference.
    by nunofcc
    Good night,
    I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
    Thank you for your help....
    10-04-2020, 01:59 PM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
    Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
    by sam_sam_sam
    This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
    Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
    07-07-2024, 02:34 PM
