Creality 3 printer switching power supply recapped
    • Jul 2011
    • 6057
    I decided to recap this power supply before using my second 3D printer
    • 31138
    Re: Creality 3 printer switching power supply recapped
    that's a nice oldskool design, even a fiberglass board!
      • Jul 2011
      • 6057
      I am glad you comment about the quality of this switching power supply
      The only complaint I have about this board is that 3 output caps mounting holes are little bit off in the hole size couple of were a little bit over sized
        • Jul 2011
        • 6057
        Update
        Ran power supply on the filament heater ( about 2 amp draw ) for over 24 hours every when well
        I also modified the switching power supply and added a power supply jack for the filament heater and relocated the indicator LED to the incoming power supply housing where I can this light
        One note I have to modify the Ender 3D bed heater controller output because once it gets to temperature it cycles way to fast and plays hell with my battery backup for my computer and 3D printer this heater draws a lot of current when on I go to add a PWM controller to the bed heater and back down the current until the temperature cycle is more reasonable
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          It is.
          Classic H-bridge with KA7500. Pretty reliable when designed right.
          I wouldn't trust the label worth a damn, though.
          15 Amps at 24V? That's 360 Watts. Even at a super-optimistic 85% efficiency (which I doubt this Chinese thing will ever do), the PSU should be drawing over 420 Watts from the wall. So those heatsinks and the transformer will need to be dissipating around 60 Watts total at that power. Do you see it happening? I don't, and even less without a fan. 6-7 Amps is probably a more realistic continuous rating.
          The lack of real safety marks also doesn't inspire any confidence either.
            by sam_sam_sam
            07-01-2024, 06:34 AM
            DVR camera recorder switching power supply capacitor failure really
            by sam_sam_sam
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
            by sam_sam_sam
            03-31-2024, 02:12 PM
