Honeywell 42 watt having on/off issues under over hang solved
    • Jul 2011
    • 6057
    I bought several of these lights and the other two work fine but the one under the over hang would turn on/off issues because of the light bouncing around on the metal ceiling
    I first tried moving the photo diode but it would not turn off the light for some reason so I just made the power wires longer to the LED panel and this solution worked
  • redwire
    • 3912
    Re: Honeywell 42 watt having on/off issues under over hang solved
    It reminds me of the (Harvard?) university project where the students put the streetlight sensor at the base of the poles and made a mega blinky.
      • 31139
      idiots.
      • SoulFreeze
        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
        by SoulFreeze
        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
        After repairing the above issue, I realized the following remaining problem,
        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
        The computer recognizes headphones are connected and displays a popup in windows
        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
        06-21-2025, 09:53 AM
      • Nagyesz
        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
        by Nagyesz
        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
        How can I extend its lifespan? Could reflow help?
        It has ryzen 5 5500h, rtx 2050, no soldered ram.
        Example of the artifacts:
        03-01-2025, 11:11 AM
      • pwnjuice
        Bitlocker issues
        by pwnjuice
        Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
        Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
        Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
        01-06-2025, 05:33 PM
      • Skgod
        Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
        by Skgod
        Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
        Black screen, freeze
        The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
        When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
        So can anyone tell me what would be the possible cause?...
        10-16-2024, 08:11 PM
      • BigOof
        Marantz SR5007 popping on volume change and mute in Direct Mode
        by BigOof
        I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
        12-12-2024, 06:15 AM
