Herbalizer - Loss of temp regulation
  • caphair
    • Nov 2011
    • 1249
    Friend asked me to check this out for him. Says that the temp doesn’t regulate and just keeps increasing. Confirmed with melting plastic under the heating element.
    Does power on and let’s you adjust the temp etc but just keeps increasing regardless.
    Right away I noticed the front two legs of triac QX1 204S8E were lifted off the board (barely connected looked like solder maybe desoldered by heat)
    If I measure from T1 to T2 I get 21 Mohms and from T1 to Gate I get .700 kohms. In diode mode from T1 to G I measure .323 both directions. Does that mean it’s good or bad?
    No clue about these, wondering if someone has seen it before and/or could guide me where to look for a possible repair.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Herbalizer - Loss of temp regulation
    Can't see any damage to the legs of QX1. But since you do have a low resistance between T1 and T2 (21) Ohms on this Triac, I suggest to remove it from the board and check it again. If you still get that low resistance, it's bad.
    It's not uncommon for cheaper devices like that to burn their TRIACs. Sometimes it's due to the TRIAC being undersized for the load, and other times it's just a "random" occurrence. In any case, if it does come down to a replacement, see if you can find a slightly higher rated part. That should hopefully prevent this from happening in the future.
    Also, is there a relay anywhere installed between the heater and the TRIAC? At least I couldn't see on.
    If not, I'd say this is quite poor design, because then the heater can remain on when the TRIAC is shorted, and that can certainly be a fire hazard. On better-designed devices, the relay is simply used for connecting and disconnecting power to the heater, and the TRIAC only does the line voltage/pulse modulation to give variable power output at the heater (and hence temperature regulation.)
    Originally posted by caphair
    No clue about these...
    Same... which is quite ironic, given the text under the LCD on this PCB:
    https://www.badcaps.net/forum/attach...9&d=1603122954
    • caphair
      • Nov 2011
      • 1249
      It’s not 21 ohms but M ohms and those readings were done with the triac off the board.
      I’m wondering if the heating element itself is bad, maybe the internal thermocouple? Or whatever is used to let the mcu know the temp to regulate it?
      • redwire
        • 3912
        What's it using for the one (or two?) temperature sensors? I assume thermistors. You can measure their resistance and the voltage across J6, J7 when plugged in.
        I would measure voltage at the opto-coupler U10 LED and see if the controller is commanding the heater to be on. Careful mains is on the other side of the opto. That big X-cap can also bite.
        There's very little solder on the JST connectors on the PCB, not enough paste was used on the pcb.
        Everything looks melted so I'm not sure how repairable this is.
        • caphair
          • Nov 2011
          • 1249
          It gets very hot quick and the plastic starts to smoke. Does the heater need to be plugged in while making these measurements?
          Nothing plugs into J6 only J7 and and fan connector in between.
          Is mains on the side of the opto with QX1?
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Ah Ok, sorry about the misunderstanding.
            In that case, I second redwire's advice. See which component gives feedback for the temperature back to the board and make sure it is working properly and has good contact to the main board.
            • caphair
              • Nov 2011
              • 1249
              Forgot to mention that the display will show the temp is way above the desired setting. Not sure if that helps eliminate some things to check for?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                It does.
                That means whatever is reading the temperature may actually be working fine.
                In that case, I suggest to check the Gate drive circuitry directly connected to QX1. So that would be R61, R62, C28, U10, R63, Q4, and whatever other components you trace connecting between U10 and the MCU that drives U10/QX1.
                  • 31283
                  is this a weed burner or something??
                  • CapLeaker
                    Leaking Member
                    • 8351
                    stj prefers 12 gauge
                    • redwire
                      • 3912
                      It looks like Herbalizer went out of business fall 2018. $599 price point and 290–445°F
                      That high temperature is beyond thermistors, so they must be RTD's as the PCB silkscreen says. If the temp sensor is very low resistance then this is the case.
                      I think it's using phase-control for proportional heat control and from the zillion IC's on this it might even not use the MCU for most of the heater control. Have to know the IC numbers for U9, U5, U16 etc.
                      The display shows a high temperature above the setpoint, yet the heater is on?
                      The thing should have a safety thermal cutoff and UL/CSA/Intertek approvals.
                      • caphair
                        • Nov 2011
                        • 1249
                        While testing some things it almost caught on fire and now the display doesn't work and some plastic under the heater is melted beyond repair. I think for safety reasons I'm abandoning this repair, doesn't seem worth it. My house still smells like burnt plastic.
                        Yes the display would show the set temp but there would be bars showing it's well past that point towards the red region.
                        Appreciate everyone's input
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          send it back .tell them you want your money back because its dangerous
                          • edugimeno
                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                            by edugimeno
                            Hi!!
                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                            At a certain point, moving stuff around, I put all wires back in place and...
                            03-24-2024, 02:31 PM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            by sam_sam_sam
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
                          • прямо
                            TRIAC circuit
                            by прямо
                            Anyone is familiar with a TRIAC circuit?
                            I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
                            With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
                            Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
                            My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
                            04-27-2024, 02:12 AM
                          • sew333
                            Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                            by sew333
                            Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                            So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                            So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                            I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                            06-14-2024, 07:30 AM
                          • edugimeno
                            Repairing a ENERTRES Biomass BI-650 heater
                            by edugimeno
                            Hi all!
                            A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
                            I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
                            I checked the board at home and this output is driven by an...
                            07-28-2025, 04:32 AM
