SMPS Resistor confirmation
  • tester272001
    • 91
    I have not done too much SMPS repair. The resistor in this pic looks like a 0.68 Ohm 5% value correct? It is OPEN. The zener across it is a 36V that was shorted. When did they start making SILVER multipliers ? (if that is truly what that value is). if this is a 0.68Ohm Is a 1Ohm a reasonable sub? thanks folks!
    Looks like a 2 watt size ?
  • R_J
    • 9588
    Re: SMPS Resistor confirmation
    gold & silver multipliers are common, the value is correct, but I suspect there is more wrong. Where is the resistor located? is it in the source lead of a mosfet? If it is the source resistor, a 1Ξ© would not be a good choice.
    That to92 transistor looks like it might be damaged, cracked.
    Post a couple pictures of both sides of the complete smps, What is it from? that might be helpful.
    • tester272001
      • 91
      I did not notice that transistor! thanks - here are both sides... the rectifier on the AC mains I replaced but it blew immediately. so those two are still missing. it is a full wave bridge there... Anything that is raised off the board was shorted and I raised the new part until I finish diag. the resistor I asked about was OPEN. All the other components appears OK from a multimeter perspective. The MAINS cap is .5 Ohm on ESR so thats good. This was a victim of lightning
      • tester272001
        • 91
        My next step after fixing the resistor was going to be pull the transformer (on the output side of the MOSFET) and see if does not blow the fuse.
        • R_J
          • 9588
          The transformer is not the problem, removing it will prove nothing. if the mosfet is not shorted, then I suspect there is a short on the secondary. I see someone replaced D650 and I suspect they used a regular diode and not a fast recovery type.
          If Q602 is damaged, then I suspect the Q601 mosfet is also damaged, R611(0.68Ξ©) is in the source of the mosfet and if the mosfet turns on hard or is shorted, R611 will blow.
          What are you using for diodes D601~D604? I suspect they are also wrong.
          Is that electrical tape as an insulator for the mosfet? that is wrong in so many ways.
          I suspect Q601 shorted, causing R611 to open, this supplied +160vdc via a drain to gate short that damaged Q602 and likely other parts in that circuit
          • tester272001
            • 91
            For the primary rectifier diodes I used what I had on hand. 1N4007 the originals are 1N539BL. The zener was 1ZB36BL. What looks like electrical tape is thermal padding I had for a big SCR since the MOSFET is not a plastic package it will short. So I put that non-conductive thermal pad in there temporary to see if it all would work. I was not planning to RUN that way only to test.
            • R_J
              • 9588
              On the mosfet with the tape, did you insulate the mounting screw, or just not use one? The zener is not that critical as it is just used to clamp any high frequency spikes across R611 when the mosfet is operating.
              Q602 must be replaced if damaged as it controls the switching of the mosfet
              • tester272001
                • 91
                I did not put a screw since it would likely short I will check Q602 - do you think i can get by with R611 as 1 Ohm? I def. do not have any SUB-ohm on hand.
                • R_J
                  • 9588
                  Using a 1Ξ© for R611 will change how the circuit operates, the voltage across the resistor will be almost double and that might upset the base voltage on Q602. Q602 sure looks bad from the picture.
                  You may want to check Q501 mosfet and D501, D502, D605, & D607 also.
                  • tester272001
                    • 91
                    I appreciate the feedback RJ! i will check q602 and see about getting a low ohm kit.
                    • redwire
                      • 3912
                      There are repair kits for these BA21N0F0102 Emerson/Philips/Magnavox power supply boards, it might make repair easier. Or at least point to the parts to test.
                      • R_J
                        • 9588
                        I would suggest getting the repair kit as recommended by redwire, it may be cheaper and you will have all the correct replacement parts. Then it might be wise to use a 60~100 watt incandescent lamp in series with the a/c line to check the power supply, the lamp will limit the current if there is still a problem.
                        • tester272001
                          • 91
                          Great idea fellas! The bulb trick I have heard of before, I will give that a whirl. I see that kit on ebay and its reasonable. Thanks for all the help and suggestions! Red and rj.
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
                          • chth96
                            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                            by chth96
                            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                            Since then, This AC/DC adaptor have been out of order.
                            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                            And Is there any possibility that it will suddenly explode as well as to be out...
                            12-03-2023, 04:40 AM
