Logitech G29 Help request to find smd transistor reference.
  • ploggy
    • May 2021
    • 7
    Re: Logitech G29 Help request to find smd transistor reference.
    Heh I folded like a cheap suit and purchased a replacement Mobo for my wheel :P
    I wasn't 100% confident even if I found the right part that I could replace it.. the part is damn small lol
    Even tho I now have a working wheel I'll keep an eye on this page just just incase someone confirms the ic and has replaced it successfully.
    Thank you for the help, I appreciate it.
    • Francesc V.
      Diode marked as "E57".........not able to find it by reference
      by Francesc V.
      Hi:
      I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
      I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
      It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
      Any idea? it's a 6.6V zener?
      06-14-2025, 09:56 AM
      LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
      This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
      09-12-2024, 01:58 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • everell
      EVGA 500 watt with fan twitch
      by everell
      This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It...
      09-15-2022, 05:50 PM
    • Francesc V.
      Dell dockstation WD15 is dead
      by Francesc V.
      Hi:
      A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
      Here are the findings, followed by good pictures. :-)
      When pluged in, LED3 glows
      Measuring some voltage in the circuit.
      Inductors
      - PL202 has 5V
      - PL201 has 3.3V
      - PL300 has 1V
      V. Regulators
      - UT30 has 19v as input and 6V as output. It seems ok.
      - UT27 (same reference as UT30, has no input/output voltage).
      Thermal find...
      07-09-2025, 12:12 AM
