Amp limiting controller?
  • Hornnumb2
    • Feb 2011
    • 218
    I have a frozen drink machine and for some reason it froze up the other night and stripped the plastic gear that operates the mixing paddle. Is there something that I could buy to put in line with the paddle motor that when it got to a certain amp draw that it would shut the power down to that motor? Thanks Michael
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Amp limiting controller?
    resettable fuse
      • Jul 2011
      • 6070
      You would have to know what your amperage is when the product is where you want it then you have to test the resettable fuse what there rating is and when they trip is two different things so it requires some testing
      But I would recommend checking a few things first
      Make sure that your temperature sensor controller or a mechanical thermostat is working correctly if has one
      It could have a refrigerate pressure control you have to know what type of refrigerate was used then take a pressure temperature chart to see what pressure at a given temperature because you could have a bad control or low on refrigerate charge you will need a set of gauges for this test
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        A "resettable fuse" usually means a positive temperature coefficient thermistor that is low resistance until a particular current threshold is exceeded, at which point it goes high resistance. After it cools down it returns to low resistance, "resets".
        PeteS in CA
        • redwire
          Exploding motor cap on Ryobi electric pressure washers - product recall
          by redwire
          Exploding motor cap on Ryobi electric pressure washers.
          Recall is for 764,000 units and 16,000 sold in Canada.
          "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
          Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
          Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
          Safety vent too expensive! DELETE DELETE
          08-31-2025, 11:03 AM
        • cjard
          A motor controller is a power supply, right?
          by cjard
          Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
          10-14-2020, 01:24 PM
        • master3112
          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
          by master3112
          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
          10-29-2024, 09:32 PM
        • Bloopeta
          DMHC DC Motor Controller for Electric Quad
          by Bloopeta
          Hi, I was given a Funbikes 96 36v 800w Electric Quad.
          Problem is the guy who had it connected the batteries wrong. It has 3 12v batteries in series, but he connected the 3 batteries in a complete circuit (diagram attached to explain, please excuse my drawing lol) and connected them to the quad, and said the motor controller made a fizzing noise and smoked lol.
          Funbikes no longer stock a replacement controller, and I am unable to locate one online with the part number.
          I opened up the controller, and immediately could see some blown caps, so I have replaced...
          11-02-2021, 11:01 AM
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
