I have a frozen drink machine and for some reason it froze up the other night and stripped the plastic gear that operates the mixing paddle. Is there something that I could buy to put in line with the paddle motor that when it got to a certain amp draw that it would shut the power down to that motor? Thanks Michael
Amp limiting controller?
Re: Amp limiting controller?
But I would recommend checking a few things first
Make sure that your temperature sensor controller or a mechanical thermostat is working correctly if has one
It could have a refrigerate pressure control you have to know what type of refrigerate was used then take a pressure temperature chart to see what pressure at a given temperature because you could have a bad control or low on refrigerate charge you will need a set of gauges for this testLast edited by sam_sam_sam; 09-01-2020, 05:59 PM.Comment
A "resettable fuse" usually means a positive temperature coefficient thermistor that is low resistance until a particular current threshold is exceeded, at which point it goes high resistance. After it cools down it returns to low resistance, "resets".PeteS in CA
****************************Comment
by cjardHoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
by master3112I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on... -
by BloopetaHi, I was given a Funbikes 96 36v 800w Electric Quad.
Problem is the guy who had it connected the batteries wrong. It has 3 12v batteries in series, but he connected the 3 batteries in a complete circuit (diagram attached to explain, please excuse my drawing lol) and connected them to the quad, and said the motor controller made a fizzing noise and smoked lol.
Funbikes no longer stock a replacement controller, and I am unable to locate one online with the part number.
I opened up the controller, and immediately could see some blown caps, so I have replaced... -
by juergenbHi,
i am asking for some Help.
I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
So i got a few of these from Banggood.
I swapped the motor and now i have a new fault condition.
In a working Frother you would press the start button, it will light red and work for a few minutes.
If you press longer it will light blue and just mixup the milk.
With the new Motor it just starts... -
by sbt123hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
- Loading...
