Psom circuit help
  • redwire
    • Dec 2010
    • 3912
    Re: Psom circuit help
    This is a custom Ford IC. IC1 70013FB Motorola looks like five subsystems in it. 9V regulator (pin 1,2,16) with IGN shutdown (pin 6), 5V regulator (pin 16 in,15 out), variable-reluctance pickup amplifier from rear axle (pin 10,11), and then that speed output (pin 14) to the MCU or cruise control. Reset pulse (pin 15). GND is pins 4,5,12,13.
    It's important to get at least 9V and 5V power up and running.
    Mystery pin 8 seems to go to the MCU or the white connector. There might be a pulsing watchdog feature in the IC, so the MCU sends pulse to it on pin 8 and if nothing there, then IC1 a reset pulse gets made.
    Really with no datasheet this is just guessing.
    "666 Hz" -> LOL!
    At 666Hz I hear music, AC/DC Highway to Hell... playing in the Ford.
    • Hornnumb2
      • Feb 2011
      • 219
      So if you were a betting man, I should remove the IC1 from working board and hope that takes care of problem?
      • Hornnumb2
        • Feb 2011
        • 219
        Would you think IC4 is some type of controller?
          • 31316
          ic4 is a microcontroller - probably from motorola,
          ic2 is an eeprom for running data - probably your mileage etc.
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • dicky96
            Lynx RS4-2000 switch mode PSU does not start
            by dicky96
            Hi guys
            This PSU is actually in an amplifier, but it is the PSU itself that has a problem
            I have spent quite a lot of time trying to diagnose this and the more I get into it the more puzzled I become
            It has a Standby, or Startup supply (15V) generated by a TOP245GN and this is working
            The main SMPS is controlled by a SG3525A and it does not start up
            According to the datasheet
            https://pdf1.alldatasheet.com/datash...A/SG3525A.html
            This SG3525A will shut down if pin 10 is high, or pin 9 or pin 8 are...
            11-17-2021, 06:20 AM
          • Smilz
            M2 Mac mini (820-07529-07) Circuit ID Help
            by Smilz
            Hey all,
            this is my first post on this site.
            I just got my hands on a M2 Mac mini (Board Number 820-07529-07) that was described as "no power/logic board defective". As I just got into microsoldering I thought that's a great way to practice my skills under the microscope.
            However, this board Clearly has been worked on before and as there are no schematics for the Mac minis (AFAIK) I need some help figuring out what that circuit does.
            I already ordered a iCloud locked donor board to swap the parts, but some more information about that part of the board would be...
            12-03-2025, 11:01 AM
          • Tarot Superstars
            Short Circuit tester
            by Tarot Superstars
            Hello.
            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
            Link
            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
            https://www.youtube.com/watch?v=0eixDdCpiO4
            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
            09-25-2023, 09:11 AM
          • Alimash
            op amp circuit function?
            by Alimash
            I am repairing a ups which doesn't turn on ,it has the following ICs:
            SG3525 used to drive inverter mosfets.
            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
            A LM358 and TL074 for control mechanism and of course the uController.
            The SG3525 is shutting down every time the ups is turned on.
            I want your help to know the function of LM358 and TL074 in the system.
            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
            07-31-2025, 07:45 AM
