SOT23 transistor HELP!
  • finntricky
    • Jan 2014
    • 449
    i have a video switch box with 3 AV outputs, this is a rear double screen video system in my car, the switch box started to smoke so unpluged the 12v supply,
    on inspection of the internal board, i have a N010X SOT23 that has burnt,
    my problem is that i can't find any of these transistors with the same markings,
    i have no idea of the values.
    maybe someone here will know or maybe there may be an alternative, that i can replace with. added this pic that i found with google.
    thanks for any help you can give in advance
  • R_J
    • 9625
    Re: SOT23 transistor HELP!
    They seem to be NK2302A
    • redwire
      • 3912
      I find:
      N010X alternates APM2302,SSS2302,ME2302,AP2302,STS2302,MT2302.
      N029I alternates STS2304,Si2304,AO3406,NDS355AN,AP2304,APM2306,CES2304.
      Is there a pic of the board, to see if these switch power for battery charger/camera or what. Some mosfets are only 16V rated which is too low for a car if switching 12V power.
      • R_J
        • 9625
        The N010X could be the P-Channel mosfet, AO3401 or equivalent
        • finntricky
          • Jan 2014
          • 449
          Originally posted by redwire
          I find:
          here is a pic of the board, i have arrowed the N010x,
          i thought it was N channel, but during my search have also come across P channel ?
          • finntricky
            • Jan 2014
            • 449
            also taken some close ups
            • R_J
              • 9625
              I would guess it is a P-channel mosfet, Best to check the voltage on the source and drain pins, with respect to ground.
              The 1AM seems to be a (S)MMBT3904L
              • redwire
                • 3912
                It looks like a mosfet switching remote power to something. I would check the load it supplies/wiring is not shorted, like a second camera or the LCD screen. The mosfet would not just cook like that on its own because there are gate resistors. I would say it was overloaded and where is the fuse.
                You would have to check the drain and source traces, where they go to confirm if it is P or N channel. Cathode of D1 looks like +12V power so if Q9 source goes to that (power) and drain goes to the load, it is a P-ch high-side switch. Q9 drain goes to three vias, so I would follow those- they probably go to the load so that means it's P-ch.
                Samhop semi taiwan does not give marking codes, they have a STS2301 P-ch. I would put in AO3401.
                Lisen PBC3117-1-01 Main V1.1
                • finntricky
                  • Jan 2014
                  • 449
                  you are right redwire, there was a short on a video wire, inner and outer, only found it after the burn out of the N010X when i was checking the mini 8 pin din plug and socket. so im going to need a new cable as well.
                  to be honest, this is the first time i have had a look at something like this, i im at a total loss as to where to start, so i will buy some of the P channel, as this seems to be the best guess, what would happen if i put the wrong one in ?
                  • redwire
                    • 3912
                    OK that makes more sense.
                    Nothing can really go wrong putting in a new P-ch mosfet. The AO3401 has better specs than the other generic parts, and all have the same pinout.
                    • finntricky
                      • Jan 2014
                      • 449
                      just to let you guys know, replaced the sot 23 with the A03401, and all is working fine,
                      next mission is to try and find the 8 pin slim mini din extension lead to go from the switch box to the monitor, can't seem to find anywhere in UK to buy them from.
                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 05:30 AM
                      • Nilssen
                        Need help identifying a SOT23 NPN transistor, labeled 6CE
                        by Nilssen
                        As topic sais, i need help identifying a SOT23 NPN transistor.
                        Marking on the transistor is labeled 6CE, will try uploding a picture.
                        10-12-2023, 12:53 PM
                      • Natob82
                        Micro Momentary Push Switch?
                        by Natob82
                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                        12-21-2022, 05:22 AM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
                      • SluggerB
                        Help making a switch work the opposite way with a relay
                        by SluggerB
                        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                        02-07-2025, 07:57 PM
