New TME mod idea.
  • Retrorockit
    • Feb 2020
    • 105
    New TME mod idea.
    TME=Time Management Execute.
    This is a function on some PLL chips that allows the BIOS to set a hard upper limit to the FSB. A high signal during POST sets the limit to a value that's slected on other pins of the PLL.
    A mod on older computer was to pull down the TME signal with a resistor to ground. Later PLL chips multiplexed a 33MHz output to the PCI bus on the TME pin to defeat this.
    My thinking is if you put a diode to allow the PCI frequency out you should be able to put a parallel resistor on the input to unlock the TME limit. Resistor in,diode out.
    Do you think this would work?
    What specific diode or resistor parts would be needed for this?
    I think I can handle the soldering for this myself.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8707
    Re: New TME mod idea.
    who knows, depends on the PLL chip and how exactly it's prohibiting overclock...
    • Retrorockit
      • Feb 2020
      • 105
      Truste Mode Execute is the another term for this. I've seen it called the other also. Maybe different chip vendors.
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        by mikey5791
        Hi to all forum members,
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • chth96
        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
        by chth96
        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
        Since then, This AC/DC adaptor have been out of order.
        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
        And Is there any possibility that it will suddenly explode as well as to be out...
        12-03-2023, 04:40 AM
