best value induction heater diy style
  • petehall347
    • Jan 2015
    • 4448
    wondering if anyone can guide me through the minefield of diy kit induction heaters ? its for mainly hotting up seized nuts on cars etc .
    i see by design these things can fail pretty quickly if badly designed .
    maybe some of you have and use one that can be recommended to me ?
    • 31265
    Re: best value induction heater diy style
    just wrap some turns of the thickest copper wire you can find and then get a stepdown transformer to output a volt or 2 at some huge amperage.
    • petehall347
      • Jan 2015
      • 4448
      what frequency ?
        • 31265
        i dont think it matters.
        • diif
          • Feb 2014
          • 6978
          • England
          After years of wrangling with rusty bolts on cars I bought a DeWalt DCF889. I've yet to meet something it can't undo.
          • petehall347
            • Jan 2015
            • 4448
            will the coil not get hot at 50hz ?
            • petehall347
              • Jan 2015
              • 4448
              i work on plenty of stuff thats so seized from rust even one of those wont undo the nuts/bolts without heat .
              i have a decent blowlamp but it tends to set fire or melt plastic and rubber parts close by .
              this is why i thought a decent induction heater that only heats what you want to get hot .
              • diif
                • Feb 2014
                • 6978
                • England
                Fair enough, I should count myself lucky I don't have to work on such rusty stuff.
                • edugimeno
                  Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                  by edugimeno
                  Hi!!
                  Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                  I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                  At a certain point, moving stuff around, I put all wires back in place and...
                  03-24-2024, 02:31 PM
                • madan1
                  Diesel heater emergency power supply / poor man's UPS
                  by madan1
                  Hello everyone.
                  Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                  12-18-2022, 08:05 PM
                  Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                  I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                  I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                  12-16-2023, 08:39 PM
                • sew333
                  Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                  by sew333
                  Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                  So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                  So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                  I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                  06-14-2024, 07:30 AM
                • janos6662000
                  Ariston Hotpoint KIB633CE Induction Hob repair assistance needed
                  by janos6662000
                  Hi
                  I bought a faulty Ariston Hotpoint KIB633CE Induction Hob
                  It has 3 induction zones, 1 is working and 2 not.
                  I was expecting a faulty IGBT. Indeed, that was faulty, but unfortunately it also has some damage on the driver part. The second IGBT on the same microcontoller does not appear faulty, but that zone was nto working neither.
                  I attach some pictures.
                  Right now my biggest problem is, that 2 of the IGBT drivers are not looking good and i cannot find what type is it.
                  They are SOT23-5 package, pin 2 on GND and pin 5 on output, connected through a 27Ohm resistor...
                  11-01-2025, 04:22 PM
