Identify DIODE value
  • NConstantinou
    • May 2017
    • 346
    • Cyprus
    i have an AEG oven motherboard with a burned DIODE
    SMD UM 6C.
    CAN SOMEONE TELL ME WHAT THE VALUE IS!
    THANK YOU
  • R_J
    • 9576
    Re: Identify DIODE value
    Maybe it is a CZRF12VB. Post a picture of the board it is on and a closeup of the diode if possible.
    POST PICTURES!
    • NConstantinou
      • May 2017
      • 346
      • Cyprus
      • magneh
        Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
        by magneh
        Hello everyone
        Got a motorbike PCB that had 3 burned diodes.
        The smaller ones have the marking PJ78 GS1M
        And one larger one PJ78 GEX
        Can someone help me identify them so I can be able to replace with same or equivalent?
        Photos attached
        Apreciate !
        Thank you...
        05-19-2025, 07:38 AM
      • hobostove
        Corsair RM1000e - Help identify 5VSB Zener diode
        by hobostove
        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
        There's a 22ohm resistor that's melted and open, but it still has the bands.
        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
        It looks like the diode connects the source and drain of a TNY284...
        03-27-2025, 02:25 PM
      • jezzaaaa
        Identify replacement diode
        by jezzaaaa
        I'm trying to find a replacement diode for one that has gone short.
        I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
        I can't find the exact part number for sale. Similar...
        05-09-2023, 11:26 PM
      • deep000
        Burned Voltage Regulator in Monitor – How to Identify and Repair?
        by deep000
        My computer monitor ASUS VP249H stopped working, and smoke came out of it.
        I opened it and found that a voltage regulator had burned out.
        The problem is that I can't identify its reference.
        I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
        How can I find its reference, and do you think it's repairable?
        Monitor: Asus VP249H
        Board reference: 0171 - 2271 - 6083
        09-08-2024, 01:13 PM
      • cinkoxid
        Atorch UD18 DC adapter Burned smd component. I can't identify it
        by cinkoxid
        Hi guys,
        I wanted to test a DC adapter and I plugged it into my device and then I immediately smelled the cooked component. I cheked the adapter again and I discovered that it's not a DC but a 24V AC adapter
        I took apart my tester and I think I found which component burned but I can't identify it for sure and I'm not sure where could i buy a replacement part which is the same or has similar features.
        I attached a few pictures of the component. I think it's a voltage regulator but some of the markings on the component are burned.
        Name of the...
        01-30-2023, 09:43 AM
