recently my laptop power adaptor died,when i tested the external fuse (5A-250V) it was blown not knowing that the bridge rectifier has shorted i replaced the fuse with a wire and plugged it back in,there was a spark and the adaptor died again.When i opened the adaptor i found another fuse with a rating of 3.15A-250V which was also blown..Now the confusion is that shouldn't the internal fuse have blown out first due to lower rating..If it had blown first there wouldn't have been a spark when i replaced the external fuse with a wire...Both fuses are in series.
Fuse CONFUSE
Tags: None
Re: Fuse CONFUSE
Where is this second fuse located on the secondary?
Doesn't make much sense to have 2 fuses on the primary.Elements of the past and the future combining to make something not quite as good as either. -
Re: Fuse CONFUSE
Are you trying to start a fire?
Primary (5A) died when bridge blew, internal died when you BYPASSED the first fuse with a WIRE!
If you're lucky, you didn't fry everything in the adapter. If your not, crank out the bucks to buy a new one.
They're not kidding, and it's not a suggestion nor recommendation when they say "For continued protection against risk of fire, Replace with same type and rating of fuse".
Toastveritas odium paritComment
Re: Fuse CONFUSE
The 5A Fuse is located inside the plug whereas the 3.15A Fuse is located just before the rectifier inside the adaptor..does this means that 3.15A fuse failed to do its job?Comment
Re: Fuse CONFUSE
a-Ha! Fused plug. Different interpretation of purpose than "the external fuse...".
That fuse protects the cord, such as in a set of outdoor decoration lighting. If you chop the cord, it blows the fused plug. Typically a quick-blow fuse.
>>does this means that 3.15A fuse failed to do its job?<<
No. It means the excess current drawn was killed by the quick-blow fuse in the cord before there was enough time for the slow-blow fuse in the adapter to react. It's a matter of milliseconds, but it's enough to take out one before the other.
When you "hot-wired" it, the internal did its job to protect what's now left of the adapter.
Pictures and more info (make, model, etc.) will help, if you're keen on fixing it.
Re: Fuse CONFUSE
well,i got it fixed,but was confused in the sequence in which the fuses went out..its clear now..thanxComment
by BabbarI found a project in the electronics trash yesterday. A nice Argon SA1 audio amp with some electrical issue. Took it apart and saw that the 4A250V fuse was blown so started lifting components to find the short. Eventually got to two MOSFETs (model FTA14N50C) that are shorted and when i took them out the short was gone.
Now i didn't have any replacements of the same model of course but i found a couple with pretty similar spec i thought (K10A60D & K12A50D) and put them in. Also replaced the blown fuse with a 3.5A250V one. Checked another time for short circuit and plugged it in.... -
by drscootHP Modelnumber: 14-dh0061nb​
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
by whc14765Hey,
I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector... - Loading...
