Linear Transformer Rated Current
  • Krankshaft
    • Jan 2007
    • 2328
    Before I get into my question some background.
    So I pulled out my Grundig FR200 today one of those wind up radios that charges a NIMH battery (basically it's exact same style battery pack as in most cordless phones).
    I look on the back of it and it has a place for an AC adapter (a 3.4mm one with a negative tip thanks Germans) curious to see if it would charge the battery I look in the manual and it does.
    I find an old universal multiple connector switch type wall wart (300 mah rated) (which has this connector and a polarity reversal switch) flip it to 4.5V center negative.
    The unit charges fine and I unplug it so I begin thinking whether or not there is a charging circuit so the battery won't fry and I can leave it plugged in and charging all the time like a cordless phone.
    So I look at page 8 of the manual and heres where my question comes in:
    It says that as long as the maximum rated output current of the wall wart is 80-100 mah you can leave it plugged in with no problems.
    But if the maximum rated current is out of the prescribed range only leave it plugged in for a max of 2 hours otherwise disconnect the battery if you're going to leave it plugged in all the time.
    What gives here? Just because a transformer is rated at 100ma that doesn't mean that it won't supply more current if it's drawn by the device right?
    From my understanding if you draw too much current from an unfused secondary it will lead to the windings overheating and eventually stinky insulation breakdown.
    Do you guys think there is any truth to this or is it just hype to buy the transformer from the manufacturer?
  • relkin67
    • Sep 2007
    • 36
    Re: Linear Transformer Rated Current
    NiMH batteries should only be given a low amp trickle charge once 80% capacity is reached. The cells become resistive at that point and additional current is sloughed off as heat - eventually overheating and destroying the cells.
    The circuit must not have a feedback circuit to taper off the amps when the voltage of the cells signifies that they are approaching full charge.
    The manf. recommends a low amp charger because it essentially trickle charges the entire capacity - slow but safe. I would not leave on a 1A current indefinitely because it will cook the cells.
    • relkin67
      • Sep 2007
      • 36
      By 'the circuit' I meant to say, "the circuit in your radio".
      A true charging circuit will either step down current with voltage rise or have an IC that periodically does little capacitance checks to see if the batteries are still accepting charge.
      • Wizard
        • Mar 2008
        • 2296
        Cheap dumb charger relies on intentional high impedance of secondary winding to limit current and careful selection of voltage also.
        Cheers, Wizard
        • i4004
          • Oct 2006
          • 2029
          relkin, that makes no sense, according to this
          http://en.wikipedia.org/wiki/Trickle_charging
          if it stays on it should be float charger and that means it has cutoff circuit.
          ie you can't leave even the low amps charger connected indefinitely.
          it too will fry the battery...only at a slower pace.
          let me tell you about my varta "lemon" chrager and that might explain this:
          it's this
          http://www.en.varta-consumer.com/con...a-consumer.com
          and it really is a lemon! lol!
          it does this: charges with particular current (aa with 170ma, aaa with 80ma) but it has a timer that shuts it down if charging lasts more than 15hrs.
          it's not completely dumb charger, but i'ts not very bright either, is it?
          i believe you have same or simillar in your radio!
          it makes sense, doesn't it?
          you can leave your 80-100ma charger plugged in because it has self timer(perhaps simple 555 ic) that will shut it off after certain period.
          but if you connect more power, then the amount timer does might just be too long, and that can fry batteries.
          15hrs of my lemon is too long too, as it can get the batteries rather hot.
          but its problem is that all sorts of batteries can go to it.
          you have only one battery and charger made for it.
          so no, i wouldn't say it's the hype, it's just a cheap design so you must be carefull.
          but you can buy 100ma ac/dc adapter that wouldn't be grunding's.
          that should be dirt cheap.
          but the best way to charge those batteries in that radio would be to have some "smart" charger to do it.
          one with some sort of cpu that monitors everything. batteries have some "delta" parameter they need to monitor while charging...
          ie liek this
          but i still use my lemon with the "charging current=1/10th of capacity" rule adapted to battery's capacity ie time it needs to charge.
          yes, i need to check the clock.
          oh yeah, i have smart charger in one cordless phone that is otherwise unusable(keyboard is borked). but it only charges 2 aa batts and it takes about 5hrs.
          i must adapt it to use aaa too...hehe...
          • UserXP
            Transformer producing higher voltage than rated
            by UserXP
            Hello, people.
            i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
            So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
            09-02-2025, 12:42 AM
            by momaka
            03-15-2023, 10:17 PM
            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
            by sam_sam_sam
            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
            I tested the battery cells there are installed right now and they are testing good with no issues that I...
            02-04-2025, 08:08 PM
            Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
            The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
            All AP21X2SG-13 AP21X2MPG-13 devices are available...
            10-23-2024, 03:33 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
