Before I get into my question some background.
So I pulled out my Grundig FR200 today one of those wind up radios that charges a NIMH battery (basically it's exact same style battery pack as in most cordless phones).
I look on the back of it and it has a place for an AC adapter (a 3.4mm one
with a negative tip thanks Germans) curious to see if it would charge the battery I look in the manual and it does.
I find an old universal multiple connector switch type wall wart (300 mah rated) (which has this connector and a polarity reversal switch) flip it to 4.5V center negative.
The unit charges fine and I unplug it so I begin thinking whether or not there is a charging circuit so the battery won't fry and I can leave it plugged in and charging all the time like a cordless phone.
So I look at page 8 of the manual and heres where my question comes in:
It says that as long as the maximum rated output current of the wall wart is 80-100 mah you can leave it plugged in with no problems.
But if the maximum rated current is out of the prescribed range only leave it plugged in for a max of 2 hours otherwise disconnect the battery if you're going to leave it plugged in all the time.
What gives here? Just because a transformer is rated at 100ma that doesn't mean that it won't supply more current if it's drawn by the device right?
From my understanding if you draw too much current from an unfused secondary it will lead to the windings overheating and eventually stinky insulation breakdown.
Do you guys think there is any truth to this or is it just hype to buy the transformer from the manufacturer?
