Simplest 3S or 4S lithium ion protection circuit?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8667
    Re: Simplest 3S or 4S lithium ion protection circuit?
    Too expensive
    I don't think I'd pay more than a buck or so for dead packs, and less than that prorated for questionable individual cells (on the order of a dime or so.)
    So I'm cheap... next?
      • Jul 2011
      • 6024
      Yes you are real cheap but if see something like that I will PM you about it
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8667
        Hey, if people can get people to "recycle" their old battery packs for free, why can't I join in the fun? :-p
          • Jul 2011
          • 6024
          You might find this USB charging board interesting
          https://www.ebay.com/itm/5V-1A-USB-3...53.m2749.l2649
          I bought some to try out
          I will post the results after I do some testing
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8667
            Looks like for 1S, and it's limited to 500mA output?
              • Jul 2011
              • 6024
              If scroll down to the details of the board it says 1 amp unless you charge and discharge at the same time then it is 500ma
              When I test this board I will post the results and let you know what it really is
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8667
                500mA doesn't do justice these days... hoping for at least 1A preferably 2 or more...
                Then again 500mA is better than 0, I had a box that shuts off charging when itself is being charged...
                  Funny Chinese spec:
                  input Micro USB rated at 5V 0.62A
                  USB output rated at 5V 1A
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8667
                    Yeah, it looks like it charges slower than it can discharge?
                      • Jul 2011
                      • 6024
                      Well here is some results for the USB charging board that I posted earlier
                      The one thing that is nice about this board is that it has a LED that lights when you have a load on it
                      But I think it has a few small problems the first one is that when you charge and have a load on it at the same time the charging current drops down to 350 milliamperes and a load I could not see how many milliamperes it was putting out because my tester was in the way but the board gets warm fast
                      When you have a one amp load the board gets warm fast but it put out one amp
                      When you just have the charger on it only it charges at 500 milliamperes and board is some what warm but nothing to worry about
                      So in the end results are if you keep the load under 750 milliamperes you might be alright
                      If you do not try to charge and have a very big load on it you might be alright
                      Is worth the money I paid for maybe depending on how and what I want to use it for
                      If I use it on non name brand batteries and not put a heavy load and do not care how long it takes to charge and do not want to spend a lot of money on test of concept yeah this fits the bill
                      • Tarpey
                        • Dec 2019
                        Do you think a setup like that will become cheaper to build anytime soon?
                        These efficient electric log splitters are fantastic.
                          • Jul 2011
                          • 6024
                          This will tell you the status of the batteries that you are working with
                          I found this that you might be interested in
                          https://banggood.app.link/ediAr9t6v2
                          • waspie
                            Aiwa GX-770 Amplifier Protection Circuit
                            by waspie
                            I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                            I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                            It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                            11-29-2022, 09:58 AM
                          • someonenotyou
                            SY8003 instead of SY8003A
                            by someonenotyou
                            Hi.
                            I have a Lenovo HLS1C_HLS1D LA-L502P board with bad SY8003A DC/DC converter.
                            I have a different mother board witch contains SY8003 DC/DC converter.
                            Can I use SY8003 instead of SY8003A converter?
                            These are the differences -
                            • Short Circuit Protection:
                              • SY8003: Uses latch-off protection. This means that when a short circuit is detected, the device will shut down and remain off until it is manually reset.
                              • SY8003A: Uses hiccup mode protection. In this mode, the device will repeatedly attempt to restart after a short circuit is detected. If the short
                            03-05-2025, 07:54 AM
                          • Astonished
                            Fixing the Charge Circuit of the Batteries of the DC Motor
                            by Astonished
                            Hi friends of electronics
                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                            Please help me fix this circuit.
                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                            01-28-2025, 06:24 AM
                          • smaniak
                            18V Li-Ion Battery BMS PCB Charging Protection Circuit Board Plate - won't charge
                            by smaniak
                            This battery PCB is new but was put in not its original charger, and now the battery won't charge.
                            First of all BMS chip is without a name. It is 20 pins but no marking.
                            On this board, I can't understand where B- the line is connected to the board.
                            Any suggestions about the BMS Chip and other things to look for?...
                            05-11-2024, 11:30 AM
                            ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
                            Optimized Multi-Phase PWM Controller
                            with 6-Bit DAC for VR10.X Application
                            The ISL6556A controls microprocessor core voltage
                            regulation by driving up to 4 synchronous-rectified buck
                            channels in parallel. Multi-phase buck converter architecture
                            uses interleaved timing to multiply channel ripple frequency
                            and reduce input and output ripple currents. Lower ripple
                            results in fewer components, lower component cost, reduced
                            power dissipation, and smaller implementation...
                            11-05-2024, 03:10 PM
