Rechargable battery component -- datasheet needed.
  • GLInick
    • Feb 2019
    • 31
    This is for a rechargeable battery pack that needs to be rebuilt.
    I cannot find a replacement for one of the components. See pic attached -- the markings are:
    KLIXON 6MM06-AA03
    I am trying to locate the datasheet for it so I can test the old one, or find another one with similar characteristics.
    Thank you in advance for any help.
    • Jul 2011
    • 6059
    Re: Rechargable battery component -- datasheet needed.
    Give us a better picture of this battery pack
    • redwire
      • 3912
      It's a Klixon 6MM series battery protector. Datasheet https://cdn.badcaps-static.com/pdfs/...f37fa72423.pdf
      I don't know where to buy them, they are supposed be self-resetting, that one at 70C.
        • Jul 2011
        • 6059
        What type of batteries are used with this device
        Li-ion batteries or a different type of battery
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
          The bq24745 features dynamic power management...
          10-23-2024, 02:50 AM
        • techfreak9356
          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
          by techfreak9356
          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
          09-14-2023, 11:10 PM
