Improving a slow/fast digital clock
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Improving a slow/fast digital clock
    Here's some more pics of the inside of this thing. I took one with a light source behind the board to make the traces more visible like an x-ray. Sadly, nothing too interesting going on in there. I managed to work out what all those pins are for and that the clock is indeed crystal-based.
    I popped off the board which holds the buttons and the display to the face plate and I was able to spot the crystal tucked under the corner of the display there. The proprietary epoxy blob chip is directly under the LCD as well, so no need to take that out as well, since it might not line up properly again.
    That J pin we saw connects to the base of the S8050 transistor, so it's the control signal for the relay. The PWR pin is a sense wire connected directly to the unregulated rectified DC via a resistor and tells the chip whether or not the thing is actually plugged in, since it won't pull the relay when it's not, even if you manually set it to "ON". VCC and GND are self explanatory: GND is GND and VCC is a zener-regulated supply for the IC AND the battery, so now we know what the battery does too: it's simply placed in parallel with VCC and has a ceramic cap between it and GND. There IS a resistor feeding its + terminal from VCC, but it's got a single black band on it, so it's zero ohms used as a jumper, isn't it ? The relay's VCC comes from the unregulated DC as well.
    So that's about it....not much I can do to improve this thing. Funny thing is that it's sat unplugged for a couple of days now and it seems to be running SLOW now - when plugged in, it would run too fast, though I haven't done an in-depth analysis and actually watch the thing carefully, but that's the way it feels...
    Wattevah...
      • 30965
      the 2 white ceramic caps tune the crystal,
      so it or the caps may be temperature sensitive.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Oh yeah, that's another thing I forgot: temperature. I took the timer inside after swapping it with the other one, since it's normally plugged into an outlet in a balcony where it can get pretty cold when winter comes around, since there's no radiator there, though the behavior occurred during summer time too, so something is drifting there due to various reasons...
        Wattevah...
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          this is also interesting on how to fix this for me as i have a battery powered digital lcd alarm clock. it uses three triple A batteries as opposed to ac line voltage and no surprises, its china made and the time drift on it is quite terrible. its like 10 secs faster every day.
          after about a week, its 1 min fast and i have to keep setting it back and its getting quite annoying to do that every week. well, on the bright side, i wont be late for work or my appointments with it running fast and making me move faster! lol!
          i guess the chinese tuned it for their colder temperate climate and when its brought into singapore, due our hotter tropical climate, the higher temperature causes a drift in the circuit, making the seconds tick by at a faster rate.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            my mobile phone gains time .
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              #26
              Your (cell) phone should resync with the network time servers each time it acquires signal.
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                #27
                You can purchase inexpensive clocks that will sync to WWV/CHU. I keep one for my bedside alarm. Unfortuantely, the clock isn't smart enough to know (or be told!) that we DON'T observe DST so, twice a year, I have to tell it we're in a different timezone.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  #28
                  only if its set to do that .mine isnt as i dont trust it
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8691
                    That thing looks like it uses a "tuning fork" crystal oscillator though you need to closely inspect it to be sure. Then go buy a bunch of them and replace them every week until you find one that's accurate enough
                    • redwire
                      • 3902
                      Tuning fork crystals are delicate. Maximum drive level of 1μW for 32.768kHz parts so they need a big series resistor ~300k is usually missing.
                      So most circuits overdrive them, and they age rapidly or fracture.
                      The oscillator is almost impossible to work on, because scope probe capacitance a few pF upset things.
                      Hard to tell what is causing the clock to be slow/fast, it can be VCC or temperature moving around too much, or a bad oscillator design that needs tuning (caps) optimized. I would try a new crystal - if it worked when new.
                      pic from https://cdn.badcaps-static.com/pdfs/...326956ddf3.pdf
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8691
                        Note that 50ppm error is already about 30 seconds per week ... so don't get the cheap ones
                        • SluggerB
                          Digital desk clock runs fast
                          by SluggerB
                          I picked up an old school Timex T121 desk clock from a garage sale. It runs fast, it picks up about a minute or 2 minutes a week.
                          I wanted to see if there was some sort of crystal or something I could replace that would correct that. I opened it up, however I don't see any type of crystal on the board, although truth be told I am not sure what I am looking for. The only thing that looks like a crystal is a small silver cylindrical component, but that is on the LCD board, not the main board, so I don't think that has anything to do with keeping the time.
                          I know some...
                          07-01-2022, 07:25 AM
                        • socketa
                          Bestec ATX0300F5WA - fast,or slow blow, fuse?
                          by socketa
                          I bought a dead motherboard, and connected it to this PSU,
                          Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                          So now i truly got a bang for my bucks, and something else to try and fix.
                          The fuse was blowen, and the top was blowen off of a TNY276PN chip
                          The glass fuse didn't have any marking to say if it was fast or slow blow
                          So i checked the marking on the PCB thinking that that would tell me,
                          but it 's got a T/F8A printed on the board
                          So should i get a fast blow fuse, or should...
                          05-17-2022, 01:22 AM
                        • joblo37pam
                          Sharp LC-80LE844U Blinks 2 slow, 5 fast
                          by joblo37pam
                          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                          10-26-2023, 02:17 PM
                        • Comp_Pro
                          820-01949 Running Slow Fast Fan ASD Software Download?
                          by Comp_Pro
                          Hello all,
                          I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
                          11-30-2023, 05:33 PM
                        • Stephen
                          A1990 MacBook Pro 15" Turning on, loads then boot loops, fan spin slow and then fast
                          by Stephen
                          Got a MacBook Pro 15" A1990 with a board issue, The board turns on, I did a DFU revive to see if it needed a firmware patch, that was successful, however the board just keeps boot looping and turning off and on very quickly. Obviously the DATA Is there, but it wont even launch into recovery, it will just die and turn back on with Apple logo, once it gets really hot it dies, if the laptop sits for the day and is cool, it will turn on then get hot within 1 min then die and turn itself on and repeat. Once it does that it turns itself on and off repeatedly in seconds. I put a thermal camera...
                          10-04-2024, 02:50 PM
