CCTV cameras: single PSU or individual PSUs ?
    Re: CCTV cameras: single PSU or individual PSUs ?
    But how about "How would you deal with initial power on?" as eccerr0r pointed out?
    That relay circuit also needs to have hysteresis.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #42
      Originally posted by eccerr0r
      ATX PSUs? Reliable? Ever looked at this website?
      Yeah, like I said, I'm sure there ARE good ATX supplies, but only high-end ones. I'd dare to say my Corsair HX1200i is amongst them, since I can't imagine that thing would fail on me like a Deer, a Premier or a Delux, would it ?
      Wattevah...
      • Retro-Hipster
        Tinkerer
        • Apr 2019
        • 125
        That would depend on what the latch circuit is. if you're talking about the simple circuit with the relay then just turning on the primary PSU would click the relay on. Since the relay on. If the primary psu turned off, the so would the relay, switching the power to the secondary.. in terms of what could be used as a latch, you could do this with several things. You could do this with a relay and A switch for instance. ( press the switch to turn on the relay. The relay then powers itself through the output.) Give me a sec and I'll do a quick schematic. I this this could work.. You know. As a manual reset sort of deal. Haha
        “Men always seem to think about their
        past before they die, as though they were
        frantically searching for proof that they
        truly lived.”
        – Jet (Cowboy Bebop) -
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          #44
          Originally posted by Retro-Hipster
          (Still have a decent Bench supply, but meh.)
          I have a rack-mountable triple supply that is digitally programmable. Its handy when I'm dealing with something "unknown" as I can type in voltage set and max current limit -- then monitor the voltage and current without having to drag out a meter to see if the "unknown" is, perhaps, toast!
          Most of the time though, the PSU's I deal with are just from old pc's. Because I'm "the boss" I worry that taking server type hardware home would set a bad example. (We often sell our old server stuff to reseller types.)
          We break-down servers and other bits of kit -- power supplies just get tossed into a Gaylord. So, fish through the Gaylord for something that "looks about right" (chances are, it's perfectly functional).
          Biggest problem is dealing with the edge connectors that are commonplace on enterprise kit. Solution is just to solder directly to the fingers. Attached pic of the supplies I use to test powerchairs -- "(BIG) battery eliminators"). Anderson connectors are common on the chairs (high current rating, ease of connect/disconnect)
          • Retro-Hipster
            Tinkerer
            • Apr 2019
            • 125
            Okay! I drew up the schematic in everycircuit to try to explain this a little bit better. there are some limitations to the layout capabilities of everycircuit so it's a bit of a mess.
            https://netorgft4619478-my.sharepoin...RsPjNMNzawY1hw
            For an explanation of how the circuit works you can watch this video I made.
            https://youtu.be/cxZXUr33Ic8
            truly lived.”
            • Retro-Hipster
              Tinkerer
              • Apr 2019
              • 125
              Ah.. It posted my post twice. :/ also, i have been messaging using my phone.. It seems that it has auto corrected some stuff. :| oh, also, i didn't notice that the schemaic I posted had 16v on one of the supply voltages... That should be 12v..
              truly lived.”
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8662
                Ah... it would be more interesting when the supplies are symmetric to each other, which is what redundant server PSUs generally are.
                • Retro-Hipster
                  Tinkerer
                  • Apr 2019
                  • 125
                  AH, yeah, honestly this whole thing just stemmed from the thought that you could do a pretty simple active/passive failover with a relay and a few support components. ^.^; I didn't even really have an intention of drawing up a schematic, but people were asking some questions about it. (I certainly didn't intend on Hijacking Danny's thread.. SORRY DANNY!) Frankly, under any normal circumstances, I would probably just use oring shotky diodes on two supplies or use a couple of mosfet's as a stand in's. If I needed fancier I'd just go with mosfet's and a purpose-made IC with overcurrent/undercurrent and low/high voltage cuttoffs...
                  truly lived.”
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    #49
                    Yeah, well it's no big deal - good ideas are always welcome and the best one are those which come at random and completely unrelated
                    I'm always on the lookout for a good project, PSUs included, so I never pass up a good dumpster dive, although our joint doesn't seem to be throwing out stuff all that often and most of it is useless anyway. We do have some servers around, so the possibility of coming across a PSU like that is possible, but just barely, because it's unlikely to still be functional at that point...hence why it's in the dumpster behind the building, where I usually like to stroll and "window-shop"
                    Wattevah...
                    • AJ847.63e
                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                      by AJ847.63e
                      Hi Folks,
                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                      05-06-2025, 10:37 PM
                    • dicky96
                      HP1740 monitor, dead security cctv cameras and a bad cap!
                      by dicky96
                      Hi guys
                      Just a little story, some of you may find it slightly amusing
                      I did a job at one of the local hotels here in Puerto Rico Gran Canaria last week. Basically I had to get their PA system working in the chill out bar - it had all been disconnected while some work was undertaken and someone had taken the speakers down from the walls
                      Now that turned out to be that one channel on the 400W PA was not working. So I brought it back to the workshop, the problem was due to a faulty stereo/bridge mode switch. I fixed it, and installed it all on Monday. Traced...
                      10-27-2017, 08:41 AM
                    • mrdevil
                      Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
                      by mrdevil
                      Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
                      However, after about 12 months, I had a number of these stop working...
                      01-08-2025, 03:19 AM
                      Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
                      H8S Family / H8S/2100 Series
                      Ordering codes:
                      F2112TE25V F2112BG25V F2112LP25V
                      The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
                      CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
                      As peripheral functions, each LSI of the group includes a serial communication...
                      10-23-2024, 02:33 AM
                    • Lamer13
                      Asrock B365 Pro4 PSU acts as short but no short
                      by Lamer13
                      The PSUs (several good PSUs tried) act as the 12v CPU Line is shorted - PSUs start and stop right away and second try through pwbtn is impossible unless psu off-on first. When CPU line not plugged PSUs run normally. This happens only when cpu line plugged. The mosfets are not shorted. Tested every single one of them between drain and source - high side mosfets - 1.3megaohm, low side - 100ohms. Between 12v and ground on the cpu connector - normal capacitor rise from ohms to about 1megaohm. All measurements are without a cpu (btw I tried with 2 different cpus - same result).
                      So I suspect...
                      11-03-2023, 06:52 AM
