Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
    H8S Family / H8S/2100 Series
    Ordering codes:
    F2112TE25V F2112BG25V F2112LP25V
    The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
    CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
    As peripheral functions, each LSI of the group includes a serial communication interface with FIFO, an I2C bus interface, an A/D converter, and various types of timers. Together, the modules realize low-cost system configurations. The power consumption of these modules is kept down dynamically by power-down modes. The on-chip ROM is a flash memory (F-ZTATTM) with a capacity of 96 Kbytes.
    Applications
    Examples of the applications of this LSI include PC peripheral equipment, office automation equipment, and industrial equipment.​
  • supravit2000
    PS4 slim SAD-001 board - how to tell the Renesas ic is bad?
    by supravit2000
    Hi, folks! I am not pro, just watch videos and try to find the error - sometimes it works.
    So I have been sold a ps4 with no hdd which should only be replaced. The machine boots up to safe mode and after assembling a new ssd, the update process returns an error su-42118-6 (sometimes SU-41333-4) which after some research, I found out that the console is for the bin as the renesas ic must be bad. The bd drive indeed shows no signs of working order (the button for eject still beeps, though, but a cd is not accepted at all). All the fuses on the board are fine, so are the caps/resistors....
    10-03-2023, 02:54 PM
  • TortureGarden
    RCBS Chargemaster 1500 scale & powder dispenser
    by TortureGarden
    Good morning all.
    I have an RCBS Chargemaster 1500 combo electronic scale/powder dispenser that I have been using without issue for 15 years or more. I powered her up to do some reloading the other week and the LCD panel backlight & characters lit-up and then immediately, the characters faded-out, leaving just the backlight illuminated. I thought it may have been a one-off so, I tested again (and again...), with the same result.
    I separated the scale from the dispenser and disassembled the scale. Nothing obvious observed that could be causing the issue, caps look...
    02-06-2024, 07:35 PM
  • luca120
    renesas IBGT alternative
    by luca120
    some days ago my induction hob have decided to die , finally I found which component result damanged, before buy a new one to be honest I prefer to check if exist an alternative component this why isn't very cheap and here i italy isn't commecialized.
    the orginal component is: rensans mofest RJH60T4
    I checked this one FGH40N60SMD, but I don't know if could be good or not, some one could help me to find a good alternative?
    thanks to all
    Luca
    11-02-2022, 05:20 AM
  • Davemack69
    Renesas RAA 229004
    by Davemack69
    Looking for schematics for a gigabyte aorus b550 pro v2.
    Or in non available then a data sheet on its pwm controller a
    RAA229004.
    05-02-2022, 06:57 AM
  • Tom_x
    Yamaha RX-A1040 internal error
    by Tom_x
    Hi
    I have yamaha rx-a1040 with internal error message, when i plug ac cord.
    In the service menu show No Model Info! The service manual say, if the ic78 eeprom changed or corrupt, need rewrite model name
    Eeprom is renesas R1EX25512ATA00A 512kbit spi eeprom
    I readed eeprom maybe possible to repair....
    I need good dump, or procedure for program model name (i did it with htr2071 by shorting testpoint and set model name), but i can not find info for this avr
    thx
    Tom...
    08-31-2025, 03:55 AM
