What is this wire???
  • hihila
    • Oct 2019
    • 11
    Please kindly help, what is this wire? size?
    Samsng monitor 275T didn't have screen and I replace a bad capacitor but still now working. After reading "bad glue," I tried to clean brown hard glue and found out the one is burned out and falling under glue.
    What is this wire? where should i get this?
    The power supply board is BN44-00163A.
    Thanks anyway.
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: What is this wire???
    The wire appears to be standard 20 or 22AWG silvered/tinned solid copper wire, you can get this from a few online electronic component retailers like Mouser for example. But you could also try eBay/Amazon/Aliexpress/Banggood, however, there is no guarantee that the stuff you get there is real copper wire.
    And if you're asking if the stuff on your PCB needs to be replaced, unless the wire is turning green, the answer is most likely no. I know the bad glue is fairly hygroscopic, but i'm not sure if it's corrosive, but i could be wrong.
    I'm not a expert, I'm just doing my best.
    • hihila
      • Oct 2019
      • 11
      Thanks for your reply.
      Can I use copper wire 20 or 22AWG without tinned?
      If it's just corrosive, I won't touch. It's complete broken off.
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        Yes, you can use standard 20/22AWG copper wire. It actually appears that this PCB used steel links based on the color of the corrosion. But a copper replacement will work fine, just keep the wire as short as you can make it.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Use a 1/4W resistor lead (or similar component). You can preform it to span the gap between the thru-holes and then solder it in just like a regular component.
          • hihila
            • Oct 2019
            • 11
            Thanks~
            • hihila
              • Oct 2019
              • 11
              wow, it sounds easier~ so resistor won't affect the power? ohm or something?
                • Jul 2011
                • 6046
                No you just use one end of resistor wire not the hole resistor just the wire ends
                • hihila
                  • Oct 2019
                  • 11
                  got it~ thank you
                  • petehall347
                    • Jan 2015
                    • 4427
                    • United Kingdom
                    looks thicker than a 1/4 watt resistor wire . whether it needs to be as thick is the question
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      Remove defective wire.
                      Clean hole.
                      Insert largest diameter component lead that will fit.
                      Trim to length.
                      • hihila
                        • Oct 2019
                        • 11
                        Clean hole.
                        Trim to length.
                        I'm newbie~
                        any suggestion for the largest diameter component has long lead? Thanks
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          good plan
                          am thinking earth wire from mains cable .
                            • 31092
                            looks thicker than earth, i was thinking copper house wiring cable too.
                            looks like maybe 1mm in the pic.
                            • hihila
                              • Oct 2019
                              • 11
                              I only can find 24AWG and 26AWG in local store~
                              Do you guys know 24 or 26AWG is ok?
                                • 31092
                                just strip some romex < i think you call it that.
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  "Romex" (NM cable) is typically 14AWG or 12AWG here in the states. The conductor in the photos appears approximately the same dia as a component lead -- whether it is a 1/4W resistor, 1/2W or even 1W may be debatable.
                                  The OP can remove the wire and check it's diameter with a micrometer.
                                  Or, just lay it side-by-side with various component leads to "eyeball" it.
                                  (A photo with such leads would be informative -- note the dia of the holes for the other nearby components of similar dia in the photo! How many components appear to have 14AWG pins??)
                                    • Jul 2011
                                    • 6046
                                    Maybe if it does not generate any heat from it but you can use wire wrapping wire if you put a few of them together and twist them together and the diameter is not bigger than the hole in the board
                                    I have have done this before and it has worked for me
                                    Or if you do use 24AWG wire remove the insulation from it if it generates heat
                                      • 31092
                                      unwinding a choke from a scrap psu is also a good source of copper wire.
                                      • Curious.George
                                        • Nov 2011
                                        • 2305
                                        • Unknown
                                        You'd have to sand the "varnish" off... (at least on the ends of the salvaged length)
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • mitsu2k
                                          The Real Dangers of conductive glue.
                                          by mitsu2k
                                          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                                          Here is an experience I...
                                          04-16-2023, 06:29 PM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
